it is a sma connector so it is either gps or onstar, if it is onstar then you don't need it anywayIdentified all the others but not sure what this blue one is for
I bought a adapter that fit for mine, but I believe you can just trim the plastic part off the factory connector and then it will workYeah shape is all wrong. It said a mini usb to usb would fit
it's just mini usb, the plastic part is what is stopping it from inserting all the way, but the adapter you bought should workI bought this one
Metra AX-USB-MINIB USB Port Adapter
Allows you to connect the factory USB port on select 2010-up American vehicles to a new car stereowww.crutchfield.com
It just looks like the metal shape is different
This is my next test. Gotta find a mini hdmi device I can test thisif you have the 3rd row drop down screen that is a seperate issue, 2nd row and 3rd row video have to be patched together to make the 3rd row work
for video output? should work with the built in rca and anything you can throw a on thumb driveThis is my next test. Gotta find a mini hdmi device I can test this
What head unit are you installing there?So I got the usb to work. The metal contact was definitely not the right shape. I removed the plastic from the adapter and forced it on. The metal reformed to the shape of the connector and it works now.
you need to be sure you have a couple things set correctlySo I got my laptop displaying on the front screen but nothing on the rears. I am not sure if it will only work from the RCA input from the rear of the center console or something. I dont have something to test with, Illl need rca to hdmi converter to test
