Cold Starting issue
opfor2
Riverside County, CA
It it's not one thing it's another!!!! I had a few extra $$ to play with so I replaced the Throttle body assembly w/ Genuine GM 12629992, MAF sensor w/ACDelco 23256991, and the Temperature sensor w/ACDelco 213-4514. Now when the engine is cold like early in the AM cold it sputters, stalls and backfires but once the engine is warmed up, she purrs like a kitten and the rough idle issue I had before is no more. I did notice that the new temp sensor's plastic part where you plug it in is black while the old OEM one was white. All parts where purchased from Rockauto. I'm going to which the old temp sensor back to see if the issue resolves. Any other things to look at??
j91z28d1
I think there's an idle relearn for the new tb too?
check the resistance on both temp sensors first thing in the morning too. might help test the new one.
opfor2
opfor2
I did the relearn with my bi-directional code reader so I don't think that's the issue for the truck idles fine once warmed up. I switched the old sensor back on and we will see what happens in the morning when its cold out
strutaeng
Dallas, Texas
Reinstall the old sensors one by one, in the cold morning and see which one makes any difference. May have to do it over several days since you say it runs fine after it starts.
opfor2
opfor2
Thats what I'm going to do. I already replaced the Temp sensor for my line of thinking is it has to do with the cold temp and it's 48 outside so we shall see. The next will be the MAF.
opfor2
opfor2
***UPDATE*** Replaced the new ACDelco sensor with the old one yesterday and this AM with the temp being 48, the truck fired right up without any issues. So, I guess I received a defective sensor. I will be ordering a new Genuine GM sensor from Rock.
Thank you all for your feedback this is an awesome forum.
justinakay79
