Charge controler generator
nonickatall
Germany
Hello,
since a few days my aftermarket audio switches off regulary and comes back directly. Now i have seen, that in this case the gauge for the battery is going up to 18V, sometimes drop below 12v. Propably my charge controler is about to die. I made a pic of my generator and found that fitting part:
https://as-pl.com/en/p/ARC0135
My english is not so good, so i question myself, if the charge controler is part of the "Alternator rectifieror" or is it located somewhere else?
Or does anybody has an idea, what else could cause this problem?
Car starts, battery charges, i have no other electrical issues.
Thank you in advance
Hello,
before rebuiiding the alternator I would have the battery load tested to verify it is working properly, sometimes if the battery is getting weak this will make the alternator work "overtime".
pressuming you are not getting any battery/charging light errors
Donal
Americus Georgia
Hello,
I foget your year model, but I am thinking that the ECM/PCM controls voltage to the field coil, therefore controlling alternator output. And a battery with internal shorts/opens intermittently will cause eratic voltage output. And other circuits shorting and then loosing contact can also make the alternator crazy.Maybe connect your VOM so you can see the display and watch to see if the meter and dash gauge are the same.
his sig says 06 esky, so it will have the RVC module, but generally if that is goofy it will throw a code i.e. charging lamp/battery indicator
all grounds and battery connections should be wire brushed and cleaned up just to be sure as well.
nonickatall
nonickatall
Germany
Thank you for your answers.
I will read tomorrow for error codes, but i have no warning lamp yet. Just the audio switch off, and the gauge went crazy for only a few seconds.
My battery is not the best, but it charges and the car starts always without problems.
What makes me wonder is, in the last time, someone come with a brocken wheel bearing, then three or four people have wheel bearing problems. I am active as well in the Chrysler LeBaron convertible scene, there are very rare problems with cylinder head gaskets. Had none for 10 years, now there where 4 people in line having a blown cylinder head gasket. :oops:
Yesterday i fixed a charge controller a Seat Ibiza, what i rarely would call a car.
And immediately i have battery charge problems....
:emotions122:
AllyNJ
