TEXCHEVY
Italy
Today …front upper control arms and bumpers
Found an 8.1 complete with harness, ecm, and engine stand for $600.
Going to pull it apart. Valve job, bearings, probably rings. This will be my 6.0 replacement.
There's not a lot of performance parts--if any for the 8.1. There was a guy with an obs that did the 8.1 swap. Iirc, he also had the 4l80.
Hickman92
Started on the sound deadener for the audio upgrade, realized the stock speaker were trashed. And then stopped after getting pissed off that both rear door panels were broken. Seriously is it that hard to take door panels off correctly?
Alex_M
Yes, I've seen that.
I'm not too concerned about off the shelf performance parts. More about towing power. 300 lb/ft at 800rpm and 500 lb/ft around 3000, the 8.1 in stock form will be miles ahead. If I ever want more performance I'll have Oregon cam do a custom grind and I'll port the heads myself, but I don't see it any time soon.
Also, I'm rocking an NV4500 as of about 4k miles ago, which has been killer.
S33k3r
Dallas, Texas
Probably salvageable, but if I've got to pull the heads anyway I'm going to just pull the motor. I've been having some issues with the self adjusting clutch anyway, so we'll get two birds stoned at once, and it will give me good access to really check everything over and decide if I want to replace the piston.
If it was a junk yard motor or had a bunch of miles I'd probably just change one valve and spring, but with the motor being otherwise new I want to be sure it's all good when I use it again.
And with the amount I tow, the 6.0 even with upgrades just isnt cutting it.
Supercharge it!
S33k3r
Dallas, Texas
You anywhere near Texas? I might could fix you up.
ASG-MikeS
