Greetings here is what is going on
- I received the vehicle with nonfunctioning brakes and cannot verify if air got into the ABS
- Pressure bleed the system numerous times with no success (5 times at least) – soft peddle once started and goes to the floor.
- The booster, master cylinder and slave cylinders have all been changed
- The semi peddle is firm when not running but goes to the floor once started
- I do not have a tech 2 scanner and the one I purchased cannot access the abs. Is the ABS bleed feature available on a 1995?
- You Tube makes it look easy but there is something I am missing
- I have all the tools and skills yet this is crushing me
- Any suggestions would be greatly appreciated
