Discolored or faded cargo side panels
smokison
Looking for others that may be having the same problem I am having with discoloring/fading of the rear cargo panels on my 2023 Yukon XL Denali with Light Shale interior.
Noticed some slight discoloring when we purchased up the vehicle in April, and informed the dealer, at which time they ordered new panels. These new panels had the same problem, so were returned.
While waiting for the next set we noticed significant discoloring startin
g to occur (see pics).
Has anyone else had problems with discoloration? How did you remedy it?
KMeloney
Yeah, that's crazy. I'd bet anything that something was rubbed on (rubbing against) those spots.
CMoore711
Yeah I agree something caused those faded areas on the surface of your interior panels and it doesn't appear to be caused by the sun. If it were from the sun it would be a large gradual area of discoloration.
Those type of marks are small and isolated from either direct contact from something; a liquid chemical, an object rubbing against it while driving down the road.
strutaeng
Dallas, Texas
I was going to say probably an abrasion, but zooming in the photos look like a bleach or dye, so I would agree it was a chemical.
You can always scuff up that area and spray it with that plastic spray bomb product. Just mark the surroundings area. Try to blend it or spray to the next edge so new color matches somewhat. It's in the trunk, so probably not too critical step on the blending.
I did a small repair to a rear door panel and front seat side plastic and turned out nicely, Duplicolor product.
B-train
It almost appears as though the coloring in the plastic didn't set right in the forming process. I say this because you can see swirls, streaks, etc thar shown up around and through the piece. I'm sure exposure to air and sunlight made it fade. Or, whatever color fasting they do and/or UV protection may have not mixed or cured properly
stephanie2910
While waiting for the next set we noticed significant discoloring startinView attachment 415882View attachment 415883g to occur (see pics).
I’ve have the same exact issue. I have spent $80 on a color match interior spray that does not match anywhere near the factory color and I’ve had no luck finding the factory color code. I guess mine color is teak I thought it wasn’t an option for color bond. I picked medium oak number two and medium tan. Neither of those worked. The company has been no help. This is driving me insane to pay this much for luxury vehicle and I’m embarrassed of the back side panels.
stephanie2910
This would be great if I could get duplicolor to match my shade
I've never seen that before and it doesn't look like discoloration from sunlight. Almost looks like someone rubbed it with a chemical.
Manufacturer defect, at some point in the injection molding process the mix was not done properly. something didn't flow right or temperature in the processing was wrong, miscalibration, etc, might have passed initial inspection but shows up later, probably after exposure to heat or cold.
MonteJ
