Aftermarket fuel pump failure?
Matthew Jeschke
Sahuarita, Arizona
I HAVE to know EXACTLY what failed on my truck so it won't happen again and strand me in a remote location of the mountains I use my truck in. Any additional thoughts are appreciated!
Symptom: failure #1 driving slow speed (low power) for some time. Engine leaned out and stalled. Waited one hour, engine started no problem and ran fine. Failure #2 cruising on highway at 75mph engine leaned out and stalled. Waited 20 minutes drove 1/4 mile and same effect. Waited hour, still wouldn't start. Waited 2 hours still wouldn't start. Waited overnight started and ran like a top. On second failure I was able to hookup my tuning suite as well as wideband (although connector broke to log the wideband) while waiting for tow truck and diagnose a bit. The AFR starts at around stoichiometric (14.7:1) if I try to move the vehicle it leans out and stalls right away. If I let it idle it would go from 14.7:1... onto 20:1 then stall. I assumed rail was getting pressurized but pump couldn't keep up with demand. Oh and also cannot smell gas out exhaust when trying to start and it won't.
I bought a AEM 50-1200. My engine is a LQ9 (built no doubt) but assuming power on low end is 350hp factory for that engine that comes stock with a 140LPH pump. Pump I have is a 340LPH pump. Excess fuel pump flows gets returned to the tank.
Boiling Fuel? One consideration buying pump was that it didn't flow too much, and boil fuel. If return sends too much fuel back to tank it will sync temperature with engine in tank and boil the fuel. I called AEM when I bought pump and they thought would be appropriate size for my truck (I see other people using same pump on similar builds). I also called and asked same question when having issues. They thought of that but leaned towards a defective pump.
Bad Regulator: I have a brand new 57psi regulator and return style rail. When had issue I pulled the reference line off intake and tried to start it. Didn't work. No fuel coming out of regulator reference line either. Tapped on regulator (thought maybe stuck) no effect. Am told when the regulator fails it creates a rich condition.
Sticky Injectors: no trouble codes are tripped. Problem is intermittent. When running correctly I can log data in my tuning suite and all trims are spot on. Engine runs PERFECTLY smooth.
Electrical: swapped relays around under hood. No blown fuses. Battery voltage is correct, 12.6V (assuming alternator good as result ~ dash shows 14V when running). No blown fuses (checked ignition) and all others.
Hot pump: I tried to feel if pump was hot. I reached up top of the tank and felt the connector as best I could, seemed normal. Felt the relays and fuse under hood no hotter than expected. I also felt under tank near pump sending unit. Felt normal (unsure if that would give any idea though).
Pump Sound: pump sounded a bit labored when I turned ignition on after failure #2. I have a bit of an odd smell too. Cannot tell where the smell is coming from. I want to say it's an electrical smell but cannot say for 100% certain. The harnesses are all good though and I upgraded to 12 gauge wire.
Sending unit pump hose clamps: I was sold screw type clamps. Didn't occur to me those can loosen over time. When I diagnose / swap parts in tank I am switching to clamp style. However, don't think clamps are issue as that would be a 100% no start condition.
I suspect it's a bad pump so does AEM but I don't have a means to verify it's the pump before I hit the road again.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Spent an hour idling truck in garage to try and recreate failure. Not sure how accurate my fuel pressure gauge is... However seems when I put in my new regulator in I verified 57 PSI KOEO. I'm getting 52 KOEO right now.
There's also a weird noise in the fuel line when I hotwire the pump with my power probe. It's resonating through the whole fuel rail.
When I start the truck I don't hear that noise in the line set. It's like a squeaking noise. It's so loud you can hear it w/o the stethoscope.
Donal
Americus Georgia
When you did the entrained air evaluation, did you have many bubbles? Remember this test needs to be done with engine off and fuel pump powered separately. Capture the discharge in a clear container.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I tried it both ways. Engine off and engine on (reference disconnected). Engine off was 5 PSI lower than the regulator 52 versus 57 PSI regulator.
I have a discharge button for my fuel pressure meter. It was clear (all air removed from hose) when I performed test.
I didn't think to see if the rail had more bubbles after doing KOEO test.
I wonder if the hose collapsed in the sending unit. I had a hard time working with the style hose the sold me:
The stuff didn't like to bend when put in the sending unit. I wonder if the bends were too tight.
I'm going to install new pump with corrugated hose. Anybody know the part number that fits GM sending unit? The pump connection is 8mm 0.315. That hose I bought is 5/16" and fit the sending unit and the pump.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Cut the pump apart, cut the filter apart, took apart the regulator. Couldn't find anything that stood out to me as an issue. Pump is a FREAKING tank. VERY well built.
AEM is sending me a new pump regardless. I also found corrugated submersible fuel hose and pinch ear clamps (last post).
I have a new theory. It didn't blow any fuses. However, if the connection from battery to fuse because high resistance (is failing) it would exhibit the same symptoms. Fall in voltage, fall in pump pressure. When new pump comes I can confirm with a voltage drop test.
Anybody else rig up a small stand alone relay and fuse under the hood? I've a second project to install electric fans. I've chosen to go with a factory fuse block for that. However, I think I really do need an aftermarket fuse block for some of these upgrades, like the pump.
Any suggestions?
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Today I went out for about 15 minutes... Inspected and blew out the fuel lines. No issues there. All O-rings are good in the hoses too.
Friend mentioned possibly a bad sensor?
- Crank & Cam sensors are good (creates engine code if they are off and or I'd presume misfiring)
- TPS, MAP, MAF, & IAT. MAF has an engine code if wire breaks so don't think it's that.
I know enough to be dangerous here.
What sensor failures could create a lean condition, induce a stall, and not trip an engine code at the same time?
MAP I don't know what it'd do but collected data and it seemed to reference cells correctly in VE table during issue.
MAF I know will trip a code if it falls out.
TPS no clue if that would even effect fueling. Dynamic Airflow and Speed Density don't reference the throttle for fuel.
IAT would be wrong fuel mass if that's bad, could lean it out I think?
What systems does the P59 (our PCM) not monitor / have DTC codes for?
exp500
This and fuel pump relay control my best guess. I don't have your diagrams to study. Fuel pump pressure is also another variable on return line systems like yours. Pump should easily build both flow and pressure, and only in the top 10-20 percent or so need more.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I went through the DTC list in HP tuners and noticed, there are two DTC codes for Fuel pump.
P0230 (DTC enabled in PCM) - Fuel pump primary circuit
P1221 (DTC disabled in PCM) - Fuel pump secondary circuit low
Not sure how these are implemented as there's no feedback on the fuel pump power line, other than maybe the relay coil. I assume Fuel pump secondary circuit is if you have two pumps? Either way, the secondary DTC wasn't enabled.
exp500
What does the FSM say for troubleshooting these codes?
My guess is a run time percent or factor. But it may be for dual tank versions.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
@exp500 excellent suggestion!
Looked up P0230 in FSM. It's basically what I thought it would be, the control circuit for the relay (not power side). If the relay fails the PCM would notice no current flowing through the circuit and trip the code.
I completely tore down this pump. WOW is it a piece of art. VERY well built. Took the armature out of the pump motor. Trying to assess the windings. Find something odd but not sure if it's an issue. Most of the windings are 0.6 Ohms but a couple are just over 1 Ohm.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
This maybe the fault. First anomaly I found. The commutator is very soft which is obviously for design reasons. However, depending on where I touch the commutators and or how hard I press resistance changes by as much as 300%
I don't think that's a design feature? Least I couldn't see why it would be unless (1) it's a fail safe although higher resistance is higher heat, which I presume is bad in fuel tank. Or (2) it's a way to slowly fail the pump as brushes wear, pump pressure decreases signaling time to replace pump. Otherwise my DC motor research showed this as being a condition of loose windings where the commutator connects to the winding / inductor wires.
I fiddled with another DC motor I have apart and it didn't behave that way at all when testing commentator and windings.
To credit of pump when I installed brushes (they are spring loaded of course) the commutator resistance was consistent across the motor leads (behaved as expected).
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Don't think it was the fuel pump. Installed new pump and get same pressure reading 52 PSI KOEO.
Pressure regulator squeals?
UPDATE the squeal is a function of the regulator. Maybe a sign it's going out? I swapped another regulator in I had in my garage. No more squealing. FYI ~ Cannot return defects to RockAuto like I can to my local parts store. I can only exchange if passed refund period.
The pressure regulator also makes a odd squeal if I jumper the pump on with engine off. I have two other pressure regulators. I may swap one of the others in to see if the squeal goes away.
Anybody had troubles with Standard Motor Products? The pressure regulator in the vehicle is one of theirs...
I will likely return it / swap it as it's loosing pressure.
Pump harness was loose: Removing the old pump I noticed the pump harness wasn't locked on... It slid off which may have been the problem.
Few other observations, the aftermarket pump draws 11 AMPS at 12.4 Volts (AGM battery).
Circuit is pulling 11 amps at 12.4V continuous relay rated for 10A @ 12.0V?
The relay is a factory Omrom 8567. In open air (hood open engine cool) the relay heats up on it's own to over 120F within a minute or two. I'm reading the data sheet for those relays. It's a little cryptic but appears the lowest rating for continuous current is 10 Amps. The pump maybe pushing the relay a bit much!
Datasheet: https://omronfs.omron.com/en_US/ecb/products/pdf/en-g8v.pdf
Going to buy a 30 Amp Micro 280 (mini relay)... I think I'll leave an omron in the port though to see if I can provoke the failure again then switch the relay with the 30 AMP one.
Junction block losses: I had suspected the junction block wouldn't handle the load. However, it seems to be a non issue... On input side it's dropping 0.3V that's all the way to the load side on the relay.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
It broke down again :(
It seems as though the power line to the fuel pump is cooking the inside connection on the fuse block. I think I have to break the threaded part of the junction block to separate it and verify?
However, when pulling the relay the block smells burn. I let it cool down and truck worked fine after that.
I'm kind of wanting to just bypass the junction block and do an external relay and fuse now for the fuel pump. However, I am not sure which connector is B7 for the signal from PCM to relay?
If I was to put a larger connector inside the block... I'm not sure how to separate the fuse block without mucking up the flared end of the threads where the connectors screw in underneath....
Roilux
Senior Member
Firefighter Supporting Member
Burbank, CA
Would you be able to hear that noise or pressure regulator squeal from the driver's seat? I had an intermittent noise I've not been able to identify. After the second occurrence the fuel pump was replaced the following day when fuel line pressure dropped to 40psi. (L59 engine)
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah I can hear it from inside (although it's not terribly loud). I honestly thought it was a slipping serpentine belt. Turns out it's most definitely a noise with the pressure regulator. I tried two regulators, both exhibit the same behavior.
Diving deeper it maybe linked to my engine's PID loops in the tune. The engine idles PERFECTLY with the spark controller. Then every so often it stumbles, runs every so slightly rough and the PCM picks back up again. I think that's when the regulator makes it's little squealing noise.
exp500
Have you checked for a loose/corroded PCM connector or similar ground? Intermittant failures are tough to trace when everytime you touch it it works. The only positive is your possibles list is getting shorter.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I should have updated the post... Thanks for tip...
Looking like it was a bad junction / fuse block. I replaced it moved pump supply relay to outside of junction block. Haven't had problem since. Also it got rid of heating in junction block as I think the current draw from aftermarket pump wrecked the original fuse block
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
OMG, forget this pump. I pulled it out this evening. I'm getting so fast at dropping the tank I might as well join a nascar pit team. Three hours to diagnose, drop, install new pump and put tank back with janky stands and no room. I digress...
Was driving and it did the EXACT same thing again. Started to go lean and eventually truck stalled. I swapped battery (have been carrying a spare battery to be on safe side after new efan mod).
Truck would crank but not start. I kept trouble shooting. Threw my hands in the air and then it started up. Drove about a mile, stalled again. Coasted off road. Took entire junction block apart, started probing wires... Couldn't find fault. Started up again and drove home. Stalled in driveway. Fiddled some more again, and it started up.
I hooked up my fuel pressure gauge and there was LOTS of air in the purge hose. Truck would start but fuel pressure was all over the map (fluctuating from 25 to 45 PSI). I thought dang, the hose came loose in the sending unit. Dropped tank and hose was secured like a rock yet.
I brought a power supply out of my lab. Fed 14 volts to the pump and timed it filling a one gallon jug. Took 60 seconds. Pump sounded healthy but there was a weird sucking noise.
I next did same thing but filled a 6 gallon gas can. Took more time per gallon completing six gallons in 8:30 seconds. While filling the 6 gallon jug I put an endoscope into the fuel basket. IT WAS DRY! That pump was pumping SO fast it was SUCKING the basket DRY!
I wondered maybe it would do that w/o the return hooked up. Because the return line would fill the basket back up. Surely this pump works as I've seen other people install it, on YouTube and another friend has it but his system is returnees turbo truck. However, they used the factory sending unit basket.
I put in the factory pump again and tested it in the basket. It flowed slower than a snails pace compared to the aftermarket pump. However, it didn't suck the basket dry. Not even with the tank being nearly empty.
I think that maybe the culprit. I grew a new habit this year, that is allowing my tank to go below 3/4 full. If I got below 1/2 full it started to exhibit issues of the sending unit basket going dry. I think for the first thousand miles of having the pump or so I never let the tank go too low.
Additionally, the fuel pressure regulator squeal went away. That squeal must have been air getting into the fuel line.
kikeap
