Let's sift through every square inch of a 2013 Tahoe PPV
Caddylack
Caddylack
I have a couple of junkyard scores that I’m trying to flip:
The first is a push bar or brush guard or whatever that I took off of a 2009 Suburban. It is in great shape but just needs repainted. I think I will wire brush it and coat it nicely before sale.
Ranch Hand is the brand, and apparently it costs over $900 new:
Here is a pic before removal:
How bout like $300 after I refinish it? Notice that it adds an additional front crossmember that is super thick and sturdy.
The second score is a full set of Bilsteins for the previous gen trucks (06 and earlier).
(pic coming)
I actually got down in the dirt to remove all 4 of these with hand tools because they were so nice. Don’t be scared of the minor rust bubbles… This is the rust belt, so these might only have 1 winter on them. $225 shipped seems fair to me for a full set of 4 Bilstein shocks in great shape.
Caddylack
Caddylack
The brush guard is sold, the Bilsteins are still available. Yes, I know I still need to post pics.
In other news:
I just went through such a bad breakup that I bought a Challenger in December.
It’s a 2010 T/A 5.7 with manual trans.
Has the functional hood scoop, rear spoiler, and 20” factory wheels. Has the Super Track Pak, which I believe means basically SRT suspension and LSD rear. All of the manuals got 3.92 gears.
With V8 gas engines on the way out, I think this is a solid long term buy. It will hold value better than most vehicles.
FWIW, this is my first purchase from Carvana, so I will report on my experiences.
Caddylack
Caddylack
Guys… I have never been more upset with a vehicle than I am right now.
Today… On two different occasions, my Tahoe got stuck in the middle of the road in a residential neighborhood.
This is a full-size truck with a posi and brand new all-season tires. YOU HAVE GOT TO BE KIDDING ME.
Look at these pictures! ‍♂️
That’s one picture of each incident. Can you even believe that the vehicle in those pictures is stuck at all?
I've never driven in anything like that so I can't comment. But, yeah, both pics don't look "stuck" to me. What tires?
Caddylack
Caddylack
Continental all-season, basically new.
The only point on that topic would be that they are wide, which supposedly is a bad thing on snow and ice. Ideal snow tires are tall and skinny, I guess.
But, still, ridiculous. It’s not like I’m doing something super demanding.
EDIT: I forgot to mention that at times it felt like the brakes were independently kicking on and off. That makes me think the stabilitrak is acting up.
Hobert
Downers Grove, IL
I don't see how that is possible unless your G80 is out in the differential. I drive in Chicago western Suburbs in 2wd. Did this last week in all our snow. On hilly starts I was stopped till the Posit kicked in, and then no problem. Between the weight and the 2 rear wheels locked up and powering it was fine. You will feel the G80 lockup when the one tire spins.
Caddylack
Caddylack
I got stuck again this morning in a flat parking lot while other cars were driving right past me.
I eventually pulled the fuse and was still stuck for 5-10 more minutes until I was able to gradually inch my way out onto less slick pavement.
Maybe my rear IS blown? I hadn’t considered that until now. I was about to buy some Blizzaks or something but I really shouldn’t need them on flat ground like this.
Marky Dissod
Test it. Put one rear wheel on ice (or lather up the tread with ArmorAll or your favorite superslick tire shine stuff).
Use just enough excess throttle necessary to spin the easily spun wheel.
So long as you keep that wheel speed under ≈25MpH or so, the other wheel should lock up.
If your G80 is blown, time to upgrade to 3.42 or 3.73 and a torque-sensing limited slip diff!
Caddylack
Caddylack
The shop I just talked to thinks it’s just normal since I don’t have 4x4 but this seems ridiculous.
Marky Dissod
You're supposed to have a G80, right? If it's a 'locker' that won't lock over 25MpH, which is what GM gave you, that's one thing.
But if it won't even lock UNDER 25MpH, it's time for a torque sensing limited slip diff already.
How fresh is the fluid in it? The Eaton Gov-Lock's operation is sensitive to the condition of the fluid. Mine would have problems unlocking but has been working perfectly since I replaced the fluid, including a thorough flushing of the differential bits to get all the old fluid out.
Caddylack
Caddylack
I have never even checked the rear diff fluid, TBH. It may well be original.
Now that you’ve brought it to my attention, I’m wondering about the temperature aspect.
I have issues every single year with my trans fluid freezing, so it’s not far fetched to think the rear diff fluid may also be vulnerable. I can’t even use cheap power steering fluid because the wheel will be completely locked in the morning.
Being where I live, I'm terrible at considering freezing temperatures. The Gov-Lock requires an oil with special friction modifiers to operate properly. So, if it's full of wear debris, making it thicker, I could see how being more viscous from freezing temps could really alter its function.
Load up on some brake parts cleaner (I like the Super Tech from Walmart cuz it's cheap but effective), get a new gasket and some oil. I use Mobil synthetic (75W90), I think) cuz it works for the clutched and non-clutched differentials. But, you might need something else for your environment. I'd suggest you inspect the axle seals behind the brake rotors cuz now, with the rear opened and drained, would be a prime opportunity to replace them and maybe the bearings. If they're original, you might wanna replace them as a PM so you don't have to open it up and drain the oil again later.
Caddylack
Caddylack
Looks like I’m going to put the Tahoe on the waiting list to get ripped apart and rebuilt.
Should be a fun 2024.
Caddylack
Caddylack
What kinda "rebuilt" are you talking here?
Well… It would be a pretty mild refresh:
DOD delete with maybe a Torquer?
Supporting valvetrain
Built 6L90E, some converter
Those huge sway bars I bought a while back
Suspension maintenance, etc.
Tupapi
