Lifter tick?
bdbull
Got home from about a 7 hour trip in our 2015 Tahoe and my wife said the car sounded weird. Is this lifter tick?
I have one of the Range devices to keep it from going into 4 cylinder mode, but this sound worries me. My 2010 Avalanche had a stuck lifter a while back and it took me a few weeks of tinkering to finally get it to release.
B-train
Not sure. There is extra noise, but it doesn't sound too bad to me. How's the oil level and condition? Maybe put in a quart of ATF or some MMO and give her a good run- let it idle for a bit first and see if anything changes.
It could just be injector noise as well.
bdbull
bdbull
I literally changed the oil right before our trip so it probably has about 800 miles on it. I've put a bottle of Rislone in it before an oil change in the past, but I didn't have time to do that this time since I procrastinated on the oil change. I guess I'll just keep an eye on it.
Blackcar
Listen to this video in link there is a difference.
bdbull
bdbull
Interesting. You think the sound could be different because he had the engine taken apart and everything was open? I really don't feel like digging that deep into the engine right now. Did that several times on my Avalanche and it ain't fun. What else could make a ticking sound like that?
Blackcar
From listening to your video the shield is off intake which makes fuel injectors louder which is what I'm hearing and engine seems to idle smoothly.
You can always pull valve covers and check things out. From problems I have seen their is a bent push rod a lot of times.
bdbull
bdbull
What do you mean by "the shield is off intake?" I don't have anything removed. I simply opened the hood and took a video of the side of the engine I felt like the ticking was coming from.
I'll probably need to pull the valve covers, but damn I don't want to dig into that right now. :)
Blackcar
My mistake I seen the prongs with ball end sticking up at intake and though it had cover(insulator) over intake.
bdbull
bdbull
Gotcha. I haven't done much work on the Tahoe and saw those the other day when I was changing the oil and had to do a double take too. My Av has a much bigger shield over the engine so my immediate thought was that at some point I took it off and lost it. :)
johnsonwillie199
