ECM Reset
strutaeng
Dallas, Texas
I've never done or actually heard of ECM reset until this thread. I've certainly never unhooked the battery cables to try to reset anything.
I would think you have something else going on and your perceived battery cable disconnect correlation to truck starting is pure coincidence. The security light isn't flashing, is it? That would be a VATS issue.
You need to follow your basic, fundamentals on crank-no-fire, or no-crank (not too sure because it's not really clear based on description what's going on)...you have:
1.) Spark? If not, do you have injector pulse?
2.) Fuel? Key on, engine off, what pressure? Does it hold pressure for 15 minutes?
3.) Air? Doesn't hurt to pop the air filter box
4.) Compression? Engine was running okay? No misfires or coolant disappearing mysteriously?
Do you have spark when the truck is cranking (but not firing)? This is the first diagnosis question that needs answered, then go from there.
K
KennyGoodtimes
And it did it again today when I stopped for lunch before work it's almost like it builds a new driveline and shuts down
Super Moderator
Elev 5,280
There are some good suggestions in the past posts, and working those will likely lead you to a solution, or at least narrow things down. You may need to have a good diagnostician look at it if you want to resolve the issue.
K
KennyGoodtimes
I disconnected the battery and crossed the terminals and left it for 2 and 1/2 hours went back and reconnected the battery and it's running again
alyssadf
