What Standard Is The USB Port in The Console? (i.e. 2.0, 3.0, ?)
Scrappycrow
Air Force
Alpharetta, Georgia
Y'all,
I will be installing a splitter at the junction in the center console to power a low-consumption (16 mA) device that does not have any data connection, but I want to ensure I don't degrade the data capability from the stock port in the console. So, what USB standard will the splitter need to be?
This is for a 2013 Tahoe LTZ with the UYS-UL8 navigation head unit & rear seat entertainment.
Thanks,
Scrappy
Scrappycrow
Scrappycrow
Air Force
Alpharetta, Georgia
Well, I wanted to get my parts order done and out of the way, so I went with a 3.0-in & 2.0/3.0 out splitter. The difference in price is minimal. I'll put the stock port on the 3.0 side and just use the 2.0 for the device.
j91z28d1
to be honest on my 11 I've never found anything I plug into that USB to connect to anything. I don't know what it's for, but I doubt it's very fast.
Scrappycrow
Scrappycrow
Air Force
Alpharetta, Georgia
Well, look what I found on page 7-32 of the manual: "The USB connector... uses the USB 2.0 standard."
You can play music from a USB device or iPod using the head unit.
j91z28d1
have you got it to play music? nothing I've plugged into mine has. ever been recognized. I gave up and found a Bluetooth to aux cord
Scrappycrow
Scrappycrow
Air Force
Alpharetta, Georgia
Yep, it works fine for me. It finds all the folders with music and builds a playlist automatically. I've only tried MP3s; page 7-33 in the manual says: "Radios that have a USB port can play .mp3 and .wma files that are stored on a USB storage device as well as AAC files that are stored on an iPod." I've only tested this with one USB drive, though (a MicroCenter "gimme" 32GB USB 3.1).
tuckerrnr1
Port St Lucie, Florida
I found that I had to use a USB memory stick under 32 gb for it to read and play music in my 2010 Suburban. FAT32 format.
St. Louis
If it was USB 3.0 the port would be blue inside.
I've used memory sticks with mp3s on them to play from, or starting with the 2012 model year, you can copy these to the hard drive that's built into the radio. I believe it's a 20gb or 30gb
petethepug
Michael
SoCal
2012-14 HDD Navi secret menu tip given here …
How to pause live radio is one I’ve not heard directions on yet.
St. Louis
I know about pausing live radio, but that secret menu trick where you tap the screen so many times in the corner then enter a code only works on the 07-11
Pausing live radio is called Timeshift
petethepug
Michael
SoCal
Timeshift sounds so outdated even though it’s a new feature to OEM Navi systems.
“Try GM’s new Timeshift feature on the all new 100% electrified People Mover for 64”.
Dh1280
