TollKeeper
Random just means it hasnt defined the cylinder its missing from yet, one of the downfalls of a v shaped engine is that 2 cylinders fire almost at the same time. So it needs to find the specific miss.
Question, looks like I'm missing one bolt on #6 coil , do you happen to know what size is that, is it m6 or m8???so it went from missing on number 5 to now a random misfire only.
huh. and it drives no better and sounds the same? I'm literally out of ideas, I got nothing.
That's for a tip. I don't know what is going on with this truck but I gives me Stabilitrack again. I tried disconnecting battery wires for some period of time. But no avail. Can't wait to trade it in, before it would kill me. Once I had Stabilitrack service on 65mph. With all my family inside. I barely managed to avoid collision. I got no idea what is wrong now. I drove it yesterday it was fine, parked. And I got this thing now.from my experience when it's missing to the point of feeling it and setting codes the misfire numbers on the scanner will be steady counting up, not just a few here and there. but a almost constant counting. if you can get it to miss while driving with the scanner activatly on it. say with a passenger watching. don't run into someone trying to drive and watch lol. I do like the blue tooth phone apps ones for things like that. Just put the phone in the holder and go for a drive till it starts. then pull over and watch what's going on.
an intake leak will make the long term and short term o2 sensor trim crazy. good is around 5% plus or minus. if you're in the maxed out 15-20% you could definitely have some leak. if it's bad enough leak, it can definitely cause a lean missfire.
I've done the #8 plugs and wires on mine.. it's annoying but it's not that difficult with the right tools. laying across the engine is the worst part. I luckily have a top side creeper at work I can use. I honestly think your mechanic was just a hot head and likes easy jobs haha it definitely takes patiences. Just need the right combination of spark plug socket, small extension and flex head ratchet. the hybrid inverter is in the way thou compared to a normal truck. so I found it helpful to have the front plugs and wires off, so I could put one arm in thru the front and one down from the top to guide things.
there's some good youtube videos about getting to that back plug for normal trucks, but I don't know about the one where they pull the inner fender cover out. the hybrid stuff might make that harder.
sorry I didn't know the size of the bolt off the top of my head, I'd guess it's an m6 thou, cause m8 is a pretty big bolt, like the ones that hold the exhaust manifold on or a m8.
That ground wire was installed by me. Battery is 10 months old. Duralast bought in local AutoZone. I will try to throw some jump cables or some jump starter and try to boost that battery. If something like this happens just overnight it should be just one thing. But it happened on Christmas, c'mon. Frankly speaking I'm really happy that there is no street cleaning today I can keep it on a street till Friday, the worst thing is that I can go to dealerships anymore till I fix my Cadillac.I'm sure it feels like a waste of money, but if the battery is say 3 years old or so, especially up in the cold where you are. it might be worth swinging by a Walmart and picking up a new 12v battery for it. clean the terminals really well and see how it does.
it might make no difference, it might solve everything. hard to say but 9v sounds like an issue. did you ever find that ground wire on the front of the driver's side cylinder head?
Ok, I will give a shot tomorrow. I ordered some sockets and torque ratchet. I will let you know how it went. By the way what about the opposite side of this cable where does it go??? Maybe I should clean it too.huh. yeah, the 9v seems low, but if the battery is new that kinda rules that out. it if an actual CAN BUS Communications faul, which with such random codes like the power windows lost memory it could well be. that's very hard to trouble shoot and repair yourself without experience and the correct high level scanners and wiring diagram software. which leads me to ground being the only hope of a eazy fix.
i did finally get a chance to get a pic of the ground cable block attachment point that seems to be a pretty common problem with all these year trucks, not just the hybrid ones and especially up north. it's a pretty big deal as it's the block and driver side coil pack ground point, this pic is looking straight down from the #1 plug front drivers side. it's worth taking off and cleaning if you haven't even thou I know you've made one. I keep coming back to grounds cause I've seen them do so many random things.
Nothing has changed.So far I think my caddy bricked itself. So far am so pissed about myself and all this situation that I want to call donation truck and drop it for good.hopefully it runs better tomorrow.
man that bolt shouldn't be that tight. mine wasn't when I cleaned mine. but I was under the truck doing a water pump replacement. so I could reach up for good access.
does leave me wondering if it's tight because of corrosion and rusted up making a bad electric connection. if you look close there's a smaller wire behind the big wire on that bolt, that's the ground wire for the coil packs on that side. you probably don't have the tools and terminals handy to just cut the wires and crimp on new terminals and move them to a fresh near by bolt. my worry is if you could get an impact on that bolt that it would snap before coming loose.
Ok hopefully I won't get sick after this. It's been hard. But I did it. I heated bolt with torch lighter and managed to undo it. I cleaned terminals also I slightly sended them for better contact, also I sended the bolt head and it's washer. I added some extra ground cables. And relocated that mesh cable on firewall. Also I changed some coils. Still misfire. I added some dialectical grease on those grounding wires and I also sended down it's mounting place on a block.I don't blame you for being frustrated.
random Gremlins are the worst.
