Interior LED How to
TheBigler
Mobile, Alabama
i just did the HVAC controlls they look good
picture.php
but now i want to do my door panel controlls how do i change these and what bulbs do i need?
picture.php
97yukon
baton rouge
picture.php
picture.php
[/QUOTE
its a HUGE pain in the ass and possibily will not get good connections after all the ********(lots of filing and such). if i was you...i would leave em and ignore them as i learned to do or pull the bulbs out and ride without having light there...you know whats what anyways im sure. imo
TheBigler
Mobile, Alabama
i think im going to go with the plan of pulling the bulbs out you seen any threads or can anybody tell me how to take those panels off and get to them???
haks310
Got LEDs?
SoCal
You just have to be careful..I used a screwdriver to pry them off.
the big blue bus
richmond, va
do these look like the right kind for the hvac controls? i took dash apart to see if i could just get the ones that drop in
felskee
What are the bulbs for the foot lights,map and over head light? how many?
haks310
Got LEDs?
SoCal
bass1775
Maryland
I noticed that your courtesy lamps under the dash was changed also. What bulbs did you use for them?
---------- Post added at 07:53 PM ---------- Previous post was at 07:35 PM ----------
What color did you use? I like it.
raptorforme93
Tampa, Fl
Yea I saw that also and I think it looks sweet... I want to do something like this. Does anyone know how about how much it costs to change out all the HVAC lights and the gauge lights?
Dr. Overkill
El Cajon, CA
Guys,
Some people have said that the bulbs in their instrument cluster are soldered into the twist-lock socket things. Has anyone here experienced that on their hoes? I have yet to find a source for just the socket, so I don't want to buy the LEDs and not be able to use them, should mine happen to be soldered in. (I'd check mine, but my dash bezel is something of a PITA to R&R, so it hasn't been a priority.)
Johnny Racer
Chicago, IL
I am also wondering what the white ones would look like in the dash. I dig the blue... it matches the Alpine but with a Pewter Yukon I am not seeing that blue matches too well. So has anyone just done white? I am thinking it might be obnoxiously bright.
laneo2494
i changed everything to red too and im happy with the result. does anyone know if you can change the bulbs on the 4x4 transfer case? ive pulled it apart and found the bulbs but im not sure if you can replace them
DBLTAP
for you guys that changed them all out-did you do the door pnls as well? how many bulbs total and number of each? Thanks
bowling57
Great pics for doing this job, but does anyone have similar pics or directions for doing similar job on a 2006 Tahoe? IS it really different from these?
ScottyBoy
Shreveport, La
An 06 is COMPLETELY different. There isn't a single bulb that can be replaced without unsoldering the old one and soldering a new one in.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
What kind of t-case do you have? Are you talking about the status bulbs on a floor shifter?
Durobans
