From Crossville TN
Hoesgottaeat2
Western NY
Welcome back...
T
thingraylinetahoe
It went back to dying upon start up when cold after the new throttle body install. Numerous people couldn't figure out the issue. 4 nights ago at 930 pm central i went to start her up and she wouldn't knew the battery was toast. The next morning I took the battery to rural king and got an 800cca battery and turned the old one in as a core. I went too autozone and got new bolts for the terminals . I put the new battery in with the new bolts and the Tahoe fired up and has been running fine since no dying at all, no check engine light. If it still hasn't died again by Monday I'm going to call it fixed.
T
thingraylinetahoe
My heat and ac went completely out. So I bought a new blower motor resistor. Well my step son that's a mechanic installed it and it wouldn't work. He went to the fuse box in the cab. It wasn't blown. He got out his tester and tested that fuse spot and got the red light eluminated on the tester. So then he tested the plug and got nothing so he spliced into the plug and wired it that way. Now my heat and ac work great.
T
thingraylinetahoe
I don't think they do that. Try logging in under your original screen name if you wanna pick up where you left off.
The only issue with that is that the google account I used for that I had shut down as it was getting nothing but spam messages so there is no way to check the email and reset my password. I will probably just stick with this username and password.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Hmm I assumed my account had been deleted due to inactivity.
There is a member that posted a question yesterday evening. It was his first ever post and had never responded to anything ever and had no likes.
He joined Dec. 27, 2015
CWool
