Tech 2 scanner vs Autel
Erock7625
East Texas
I have a 2011 Yukon XL, I keep seeing people recommending getting a Tech 2 scanner but if I already have an Autel bi-directional scanner can it do everything the Tech 2 can? Or are there specific functions that only the Tech 2 can do? If so what’s the best cheap source for them, I know there are many knock-off ones and you have to order them with specific programming.
thanks!
Geotrash
Dave
Richmond, VA
thanks!
What model do you have? I'm thinking of getting one too.
AFAIK, the GM Tech2 and MDI scanners are the only ones that can do firmware updates to the various systems through tis2web, but that's a minor feature as far as I'm concerned.
Larryjb
I don't know what your Autel will do, but I think it will depend on what you want it to do. I have an older Genysis scan tool that will cycle the ABS pump for bleeding. It won't do everything the Tech 2 will, but when I got it was a good price (used). I also wanted something that I could use on our Ford Explorer, so this was the best compromise.
E
Erock7625
East Texas
I have the MaxiDAS DS808K. Buying any OBD scanner is confusing as hell as there are multiple sellers for Autel and they all use their own model number variants. I’m looking at getting another Launch has a number of good ones but again trying to do a comparison is very frustrating as there are multiple sellers.
Bi-directional scanners have come down as their is more competition now. Topdon is also a decent brand, I have their AD800BT which is a mid level non bi-directional scanner. Currently I’m looking at the following trying to pick one:
Autel MaxiCOM MK808BT Pro - $519
Topdon Artidiag Pro - $478 w/$100 coupon
Topdon AD900BT - $599 w/$70 coupon
Topdon Phoenix Plus - $920
Launch CRP919X - $465 w/$26 coupon
Launch CRP919XBT - $454
Launch X431 PROS V+ Elite - $829 w/$50 coupon
Launch X431 PROS V+ - $849 w/$70 coupon
thanks!
I've attached a Pathing diagram for the Tech 2, to show its capabilities. You may want to check this against your Autel.
  • GM_Tech2_Paths.pdf
E
Erock7625
East Texas
It really varies by vehicle, almost all of them will do ABS functions. On my Cadillac I could do thing with the trans like cycle gears and disabling torque converter lockup. Here’s a list from one of the models I’m looking at (Launch):
——2024 Welcomes 5 Additional Service Functions: 1.E.GR Adaptation 2.High Voltage Battery Detection 3.CCS (Cruise Control System) Calibration
4.G.PF (Gas Particular Filter) Regeneration 5.Cylinder Power Balance Test: This invaluable test uncovers concealed engine issues related to misfires, power loss, or suboptimal engine performance. It's a diagnostic treasure, often utilized in conjunction with cylinder compression and leakage tests to pinpoint precise problems.
——Over 31 Service Functions and a Constant Growth through Updates:
6.Oil Maintenance Reset: Reset Engine Oil Life calculation upon oil change, extinguishing oil-related alerts. 7.Injector Coding: Code new injectors for precise fuel injection control. 8.EPB (Electronic Park Brake) Reset: Re-calibrate electronic parking brake post-repair. 9.ABS Bleeding: Restore ABS braking sensitivity and firm brake pedal by bleeding the brake system. 10.SAS Calibration: Clear fault steering angle sensor memories, reset the sensor, and eliminate steering wheel warning lights. 11.Throttle Relearn: Reset throttle for accurate idling and smooth acceleration. 12.BMS Reset: Clear low battery fault data post-battery replacement, safeguarding the new battery. 13.D.PF Regeneration: Stabilize diesel filter performance by clearing particles via oxidation or combustion. 14.Key Programming: Disable lost vehicle keys, prevent theft, and add new keys. 15.Airbag Repair: Reset Airbag data and collision data post-Airbag replacement. 16.TPMS Reset 17.Air/Fuel Reset 18.AdBlue Reset 19.AFS (Adaptive Front-Lighting System) Reset 20.NOX Sensor Reset 21.Tire Reset 22.Stop/Start Reset 23.Delete Transport Mode 24.Air Level Calibration 25.Windows Calibration 26.CCS (Cruise Control System) Calibration 27.Seat Occupancy Calibration 28.Sunroof Initialization 29.AC Initialization 30.Carkshaft Position Sensor Adaptive Relearn 31.Gearbox Matching 32.Power Balance 33.Coolant Bleeding 34.E.GR Adaptation 35.G.PF Regeneration 36.High Voltage Battery Detection 37.Launage Change 38.FRM Reset 39.Fuel Alcohol Content Reset (Fuel Alcohol Composition Reset)40.Fuel Trim Reset 41.Fuel Economy Test 42.EVAP Test 43.BSI Solenoid Test 44.Seat Standardization 45.A/T Code Reset 46.Injector Fuel Rate Programming 47.Fuel Injector Balance 48.Electronic Pump Activation 49.VIN Registration (Write) 50.Camshaft/Crankshaft Sensor Relearn 51.Gear Learning 52.Reset Control Unit 53.Cylinder Compression Test 54.Cylinder Leakage Test 55.TEC Learn… and continuous expansion through updates.
——Unlock 100+ MORE Services in "Diagnostic" Menu for Specific Models:
Delve into 100+ advanced service functions for specific vehicle models via "1.Diagnose" > "2.Car Model" > "3.System" > 4."Special Function". LAUNCH X431 CRP919X's expansive automotive diagnostic scan tool effortlessly grants access to specialized functions such as Zero-Point Calibration, HVAC Calibration, Seat Calibration, Suspension Calibration; Idle Relearn, VGT Relearn, VIN Relearn, Transmission Quick Learn, Relearn Vehicle Data; SWS Initialization, ABS Initialization, Rain Sensor Initialization, Front Wiper Initialization; Clutch Adaptation, Transmission Adaptation, Fuel Injector Adaptation; Turbocharging, Hybrid Control Compression Test, and more.
E
Erock7625
East Texas
thanks!
probably the biggest difference is being able to program modules, you can do a lot of troubleshooting with tech2 it's the dealer tool
chinacardiags still sells them you just have to message them, otherwise they run about $400 on ebay for a clone
DaveO9
Vancouver, WA
https://www.obdii.shop/goods-21-GM-...-caHeaew4Gx1HAE4V_MrChhD6Q4xxk_Y4FuSCJ2FA6WIw
Is this a decent Tech 2?
If so, I will pull the trigger on this one.
Pretty sure that's where I bought mine in the last six months or so. Turned out alright for me so far. Quality is OK. I'm guessing all these Chinese clones are pretty much identical to each other anyway. I got mine quickly, not much more than a week. The only problem I've had is the connectors don't always make a firm connection. I've had to mess with them a few times to get them to work, but they always have. I've heard others have the same complaint.
Grady_Wilson
Wyoming
Get the GM software with it. 33.004 is the latest version, and that's what's listed in the description for that option.
Yeah, I saw that as an add on, which is fine.
Thanks for the heads up.
Guess I will order one and check it out.
Thanks for the responses, guys.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
How did you make out with this?
Grady_Wilson
Wyoming
I got so busy with my retirement and my upcoming move that I have not ordered a Tech 2 clone, yet.
So far, my Launch has almost everything I need to keep up with repairs but the programmability of the Tech 2 will be a huge bonus.
Charlie207
LFOD, New Hampshire
I just ordered one based on this thread, so wish me luck.
homesick
The Best Me I Can Be
Navy Air Force
I just went ahead and did the same. Does anyone have a good idea on a case?
joe
I never go thru the hassle of unscrewing and unplugging everything and it just either sits in the corner or in a box ready to go upon need.
I have tossed it in a laptop bag before while traveling.
briannorris
