03 Tahoe- Rear Differential Fluid Change: Questions
Dantheman-2003
Placerville, Ca
So I just re-geared my 03 Tahoe from 3:73 to 4:56. After 500 miles I changed my fluids. The front diff took about 1.5 quarts, which it called for 2. But I filled it as much as it would take.
The rear calls for 2.75 quarts, but I ended up putting all 3 quarts in. Stuck my pinking in there and didn't feel any fluid. Just wondering if all 3 quarts is too much. Any risks here?
Also after about 100 miles I noticed a drip. I didn't use an aftermarket gasket just Permatex. I didn't use lock tight on my bolts like some suggested, so I'll check that first. Otherwise I'll need to do it over.
Thanks!
Dan
Sam Harris
Thanks!
Dan
I ended up somewhere around 3.25 quarts when I did my girdled diff cover. Not sure if the new cover had more capacity or not, but it ended up taking more than any documentation I could find online. Filled it to just below the fill plug hole. So far, so good!
Dantheman-2003
Dantheman-2003
Placerville, Ca
@Sam Harris - Where did you purchase your girdled cover? Happy with it?
GMT800 2005 Tahoe Z71
Navy Supporting Member
No matter what, fill till the fluid runs out and then is full. Noticed a drip from where? The cover? The pinion seal? Which axle? I am assuming a cover based on what you said and assuming the rear cover. I hate assuming. It should go without saying but make sure you fill on level ground.
rockola1971
Indiana (formerly IL)
Some of that fluid will go down your axle tubes and wet them and the axle bearings in the tubes. Get that leak fixed! Blue loctite on your cover bolts aint a bad idea. Using a gasket like OEM did is a good idea. Always fill ANY fluid on a level surface. On the diffs add fluid until it comes out of the hole then put the plug in.
Dantheman-2003
Dantheman-2003
Placerville, Ca
Yeah, slow small drip under the rear diff cover right at the bottom. Less that 1 drop per day so I ain’t too worried. Just keep an eye on it and redo the cover seal next weekend.
Dh1280
