HansJr 05 Bermuda Blue Build...
Fosscore
Yes it is
110% def helps @Fosscore!!! Thanks! Gonna probably give them a call. Just want something decently backed since the wind here is pretty intense sometimes being so close to the sawgrass. You said yours had good material on the inside?
Yes it a dense, but breathable fleece-like material. But not fluffy, if you will. It is soft, durable, dries quickly after rains and holds up well to the UV. After a while anything left in the UV for too long takes its beating, but I was very happy to have that on to protect from the aforementioned reasons.
I don't think you can go wrong with whatever you choose to protect from the UV, rain, bugs, birds and be able to tie it down, especially the front and rear. There is elastic but the you know the winds find a way to flip that up and over time the elastic gets a bit loose. But the custom cut around the mirrors and snug to the body contour is really a great touch. Even for a big SUV.
I think you will be happy with whatever one you choose.
HansJr
HansJr
Waterville, Maine
You ever felt so busy that you just don’t have time for ANYTHING. :mad3: Yeah that’s been me since the last post in this thread.
Felt froggy today. Decided to pull the front and swap over the top pad. Going to my buddies house tomorrow morning to cut and reweld the bumper supports. Only took about a year and a half, but progress is progress lol. I’ll post up once it’s completed. Then next comes paint finally. I also think it took me longer to type this post than to pull the bumper and swap over the HD Pad :party36:
BeenChevy
Minnesota
Remember - Progress not perfection. Yeah, I feel you on the NO TIME FOR ANYTHING days. 5 young kids, multiple jobs, and WAYYYY to many hobbies will do that. Hard work, Trust, and following Him = doing what we're suppose to while we're here. The rest just follows. Still like how it's coming along. What are you doing for the Bermuda paint? Thinking of getting a few gallons myself or blasting it and redoing the whole thing in a new flip-flop candy here..
Fosscore
Looks good. Patience is ok too. Finished product will be sweet.
Did you paint the radiator supports black before you buttoned it up?
HansJr
HansJr
Waterville, Maine
Now that the front end is done I plan on getting the entire Tahoe resprayed in due time. May possibly be moving to Georgia here soon, so not sure where that’s going to rank on importance as of right now tho…
HansJr
HansJr
Waterville, Maine
No. I have to pull it all back apart for the little tid bits so I plan on doing it then. I did spray the mounting horns tho. I need to get some pics in the morning tho and post them. Looks good so far!
HansJr
HansJr
Waterville, Maine
Never did post the before and after pics. So here it is in the rough stage. Didn’t realize all the tabs on the donor bumper were trashed. Also needed the correct spacers. So for now I drilled and put a bolt in each side to hold up the pad. New one just arrived. Gonna swap the pad on Monday and add the spacers I made at work for the lower bracket to align it correctly. All in all I think it came out good. Lines up nicely.
Also going to mod the depo projector lights I bought last year and swap my oem brackets on there since everyone says it makes them more stable. Slowly but surely im adding the parts I’ve had laying around here for a while now
Fosscore
Yeah that’s looking great!!
HansJr
HansJr
Waterville, Maine
Thanks. Just swapped out the headlights with the Depot projectors and new lower blinker/DRL housings as well. The last set broke when the radiator blew out. Waiting till I go to work tonight to see the difference in the lighting. Also added the LED license plate lights. I didn’t swap the oem brackets onto the depot lights yet tho. Gonna see how well they ride on the highway. If they move at all I’ll pull them off and swap out the brackets. Will update night shots later.
Also got the brand new bumper pad installed and aligned. Slowly but surely it’s coming around.
Looks great.
Fosscore
Looks great!!!
Ping pong ball trick works with Depo brackets which are a bit flimsy. I went into more detail with pictures in my NBS thread. I did try to swap the OEM and Depo brackets, but did not have good success and ended up with 2 pp balls in each brackets that funnily enough worked well. There were other threads before me about this hack/trick/simple fix.
Your mileage may vary, but many that front end sure is looking sweet!! A bit of NBS envy here. Keep up the good work!
HansJr
HansJr
Waterville, Maine
Looks great!!!
Nice! I knew I read something in your bible of a build thread about the brackets. I’m gonna have to go back and look for the PPB post. Still haven’t turned it on at night lol. Life seems to always get in the way lately :p
Fosscore
@HansJr
Did a little thread searching for you on the ping pong balls and OEM vs. Depo brackets.
One of the threads I read before I did it to the 06. Turns out I guess I did trade out the Depot for OEM brackets based on the 1st thread that I posted in.
Probably the better of the threads with pictures of the balls and then I upgraded the lights, at the time, as there is probably something more betterer, I put some Vouke LEDs in and had to go back to the Depo brackets to fit the heat sink. Should be a link but at least some good info for your moving forward.
Damn seems like ages ago in 2018 doing that stuff. Miss that truck....alas will live vicariously thru yours.
HansJr
HansJr
Waterville, Maine
Thanks @Fosscore for the links above. Been a while. About to do some updating in this thread. Got a lot of parts laying around and some time to get to work. Hopefully have a new transformed truck by beginning of September. Gotta go back and read what I’ve posted so far and see what I’ve forgotten since last update :p
HansJr
HansJr
Waterville, Maine
Finally getting some time to get some stuff addressed….. like paint. The Florida sun has destroyed the roof since I’ve owned it. So hopefully this is a step in the right direction. Dropped her off yesterday. Hopefully will be a whole new chapter when I pick her up in about a week or two. Then the real work begins :beer:
Fosscore
:popcorn:
justinakay79
