TPMS Service: Tire Monitor System
mnjeepmale
2015 Tahoe LTZ. A few days ago while driving my TPMS sensor said low for the rear left tire. Then it went down to 0. An hour later the front left did the same thing. Both were showing 0. Sometimes it went to 14psi and back down to 0. Now the TPMS monitor shows -- for both tires. Another thing is when I start the vehicle I get a notification that say's 'Service' Tire Monitor System with a dismiss button.
What would be the cause of this? I have aftermarket wheels and using ACDelco sensors.
strutaeng
Dallas, Texas
Yeah, that's not that old. Some of the handheld scanners/programmers will test the sensors and tell you if they are bad.
Both of my front sensors went out on my 06 Suburban, I think within a short timeframe. I'm assuming they had all been replaced by the PO?
M
mnjeepmale
I bought the sensors when I installed the wheels back in 1/2021. ACDelco GM Original Equipment 13598772.
I'll check to see if the battery is low with the programmer tool. I forgot it has that feature.
If you know someone with an advanced scan tool or you have an OBDII adapter and one of those Apple apps that can read BCM codes, you can find out what's wrong and then deal with it accordingly.
It is not unusual for the sensors to fail together.
M
mnjeepmale
Now all the sensors are showing --
OBDII adapter shows the following codes:
C0760-29(confirmed)
C0755(confirmed)
C0755-29(Historical)
M
mnjeepmale
I checked all the tires and they are around 32-33psi. I guess the next step is to replace all sensors. Unless anyone has other suggestions to check
GlennSullivan
Westchester, NY and Jupiter FL
What I have found is depending on where you purchase the sensors, you may be getting old stock that has been sitting on shelves for sometimes a year or more. I think that some of the sensors that end up on ebay and other online marketplaces at super great prices are, in fact, manufacturer or dealer old stock that has been part of a "stock rotation" and while they work fine when first installed, they don't end up lasting very long.
trukschroeder
Can anyone tell me where the Radio Antenna Amplifier is located on my 2020 Yukon XL Denali? I'm having intermittent issues with the key fob and TPMS and the Technical Service Bulletin 20-NA-115 states to replace it but I'm having trouble locating it on the truck.
Tahoe14
Central Fl
Look in the “audio and electronics” section and the post about 6 or 7 down “fob range really blows”. It has 5 or 6 pages and you will probably get your answer in that post.
Might help a guy out and provide the link:
drivers rear side behind the plastic panels, either on the rear pillar or in that general area
Tahoe14
Central Fl
@Fless, you will have to guide me, not that computer savvy and you are a staff member and super moderator, not playing fair.
brice715
