Vibration at 80mph
Mishal
Hey guys
I recently replaced my shocks with new AC Delco shocks and have new tires and aligned together with Rod alignment and new steering shaft.
When I driver above 60 upto 80 I get too much vibration in the car where you feel the dashboard is shaking uncomfortably. Any suggestions will be appreciated thanks
rmaker
I bought a 2011 Suburban back in April. It had a horrendous shake at highway speeds, steering wheel shook. Turned out it was a bent drive shaft . Did u have the tires road force balanced?
Hoesgottaeat2
Western NY
Was it shaking like this before the work you mentioned was done? If not, I'd be looking at a wheel balance issue to start. Vibration only at certain speeds is typically indicative of the need for wheels to balanced.
M
Mishal
Yes it was shaking like this and I thought by replacing the shocks and arms and ball joints the problem will disappear but still there.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Knowing all this, from the beginning, would be a big help. Please, in the future, with any vehicle problems, it is best to share ALL info of before and after.
B-train
I had an issue with my 2017 yukon at highway speeds - around 80 mph. I could feel it in my butt. Tires were new and balanced. I pulled the rear driveshaft down and found the axle end u-joint was stiff to move by hand. No corrosion could be seen.
I replaced it and all was good. After I pulled the OEM apart, the bearings were getting dry and rusty. Easy thing to check/fix.
Been there and done that with u-joints.
ScottS-Michigan
