Looks Like I Need New Rear Shocks
bad_idea
I have a 2018 Yukon XL Denali. It appears the rear shocks are worn out. I say that because there is an audible leak from the driver side rear shock that I can run my finger over and feel. I know the truck has mag ride. I assume the rears are mag ride also? I looked them up on GMPartsDirect.com and they are back ordered (item 86787494). Is there a comparable interchange? I prefer to stick with OEM, but am open to a quality aftermarket. I am happy with the stock ride. I tow a 7k lb car hauler with a jeep on it often enough. Truck is all original, do not plan to modify it. Thanks all.
B-train
You could check car-parts.com and see if you can find some low mileage ones from a wreck
wjburken
Eastern Iowa
What is your suspension RPO code? Would be something like Z95.
I ask because the part number you mention is for the increased capacity package I believe.
Part Number 84176675 looks to be for Magride and RPO code Z95.
funnyguyMI
Rock auto has these in stock. I just ordered some. It is what they listed for my ‘18 yukon xl..
GM GENUINE 84176675
Rear; Magneride Package (Z95); w/ RPO Code AC39
GMPartsGiant.com has it in stock.
scottd
