Leveled Escalade
SmileB44Death
Seattle
Hello folks,
I currently lifted my Escalade with the bottom strut spacer 2.5 inches. I’m having a problem on the UCA hitting the droop stop over any little bump. How are you guys getting around this?
At this point I’m considering just removing the leveling kit
Dustin Jackson
I think I replied to you on another website but most people just cut that droop stop off. If you don't want to do that removing the leveling kit is another option
mb1500
FWIW 5100’s don’t over extend as much as a strut spacer does. IMO they are the best option for leveling.
Trey Hardy
Hello folks,
I’ve always cut the stops first thing I’ve never had any issues and I’ve stretched mine out to 3.5-4” before before I got my lift kit.
I am curious as to why you need to add front strut spacers in the first place. Being an Escalade, I thought that it has the Z55 suspension and automatically levels through the air shocks in the rear.
SmileB44Death
SmileB44Death
Seattle
I believe I have z95s
adventurenali92
Big Bear Lake, ca
You are correct but as you said the Z95 mad ride with the auto level control only affects the rear suspension. And in fact it gives the truck a slight rake as that’s what GM programmed them to do which makes the rear sit higher. It’s more especially noticeable that it’s leveled on the regular wheel base SUVS. That’s why a lot of guys use a kit upfront to bring it up a tad. I did the same but my suspension is different than his on my GMT800. Unfortunately I don’t have a solution for his problem.
Interesting perspective. My 07 with the Z55 suspension sits perfectly level without any mods to the front end.
j_jerry79
