Rough idle/ shuddering in idle.
iboughtatahoe23
iboughtatahoe23
When I cleaned throttle body it seemed it helped the idle the most in conjunction with using e85. Since then, I started using premium and one time I added gum out octane booster to an empty tank and filled it a bit over halfway with premium. Since then been running premium. Have only filled twice with premium tho
Dustin Jackson
@iboughtatahoe23 Running higher octane fuel is great but unless your Tahoe is tuned to take advantage of the high octane you might not be getting your moneys worth yet. Tune it to run on 91 and raise the idle and I’m sure you’ll be happy
Actually i recall usually only using e85, and then I started using premium 93 and the idle got Worse.
I’m confused now, so run e85: The cheapest gas available… or run premium??
I feel like using premium may be the issue. I could be wrong.
In the mean time I’ll do plugs and wires
These things, in stock form, do better on 89 or higher, especially in hot weather. And, yes, the cheaper E85 can be better than 93. You'll get up to 30% worse MPG. But, if the price of E85 is 30% or more LESS than 93, then you're coming out ahead as far as cost. You'll just have to refuel in 300 miles instead of 400.
I could be wrong. But, based on your descriptions, I still believe you're referring to the common/normal shudder these have and you might be disappointed after firing the parts cannon at it.
Also, the brand of fuel can make a difference and, even then, it seems to vary by location. In my parts, Shell seems to be crap and Exxon and Chevron/Texaco seem to be the best choices.
I know what you mean, but these things kinda ARE tuned from the factory to benefit from 89 or higher. They "adjust down" for the lower octane but are happier starting at and/or "adjusting up" for the higher octanes, including E85, if capable.
iboughtatahoe23
iboughtatahoe23
So keep using premium? Seems to last longer. But I didn’t notice the shuttering happening more until after I started using premium. Which makes me want to use e85 again
Marky Dissod
... yes, the cheaper E85 can be better than 93. You'll get up to 30% worse MpG.
Actually, since E85 burns cleaner (less carbon deposit buildup) in the long run, it might be ok if the E85 is only 25% less than 93. Your call.
... didn’t notice the shuttering happening more until after I started using premium, which makes me want to use e85 again
Long story short: use more E85 as your wallet allows.
(Considering doing the same myself.)
Onlyone
New Mexico
I know after this second tank of E85 my Denali runs a whole lot better than with 91. I don’t even have to barely push the peddle for it to move down the road.
kevlac
Orion Twp, MI
OEM plugs and wires will do wonders for you. Start with those first! I had the same issue. I was having shudders to the point that I thought the torque converter was going bad. The dealership told me my plugs were good ( without looking at them) and wanted to sell me a transmission. I went elsewhere to have the plugs and wires changed. The plugs were bad! The electrodes were worn away on a couple of them. The truck has driven like a dream since then. No more shudders. Like you, before my plugs were changed, e85 seemed to make it shudder less. Nonetheles, stop chasing this and get those plugs. At your mileage, you need them anyway. OEM only!
iboughtatahoe23
iboughtatahoe23
Heard! Ill be ordering plugs and wires next… I just wasn’t sure bc I haven’t had any codes for spark plugs (usually I hear bank 1 will run too lean)
If you're okay with the price of premium, then you're prime for E85. Roughly calculating, E85 will use 25-30% more fuel than non-ethanol fuel, so your MPG will suffer 25%-30%. If the price of E85 is 25%-30% cheaper than premium, then you're breaking even or coming out ahead. Talk about a life hack!
The thing is, the fuel labeled "E85" are often not actually 85% ethanol. In some places, it is. In my parts, it averages 60%. So, I wouldn't need the price of E85 to be quite that ~30% lower than premium to break even. Maybe only 25% less to throw out a figure. Even if you don't break even or better, it's okay cuz the fact that it's cleaning your fuel system and combustion chambers has value. So, enjoy the cheap gas and ignore the MPG.
If you have easy access to E85, run it for a few tankfuls and see if there's any difference. When your tank gets down to around 1/4 or so, dump a can of Berryman's B12 in it and drive it down to 1/8ish and refuel. Do this as often as you want.
If you wanna know the actual ethanol content of the ethanol fuel you're getting, you can test it with something like this: https://fuel-it.com/products/ethanol-content-tester-1
I use this one (their older version) almost every tankful to test my actual alcohol content to compare to what the alcohol sensor I recently installed on my Tahoe is reporting.
I wasn't gonna get that deep into the maths, at least, not right outta the gate. But, yes, the benefits have value and I agree that it would still be worth it even if it wasn't a wash, financially. There's also the fact that the "E85" at the pump might not actually be 85%. Didn't wanna scare him off by dumping all the info at once. :p I think he's still with us.
Onlyone
New Mexico
If you buy plugs, check the gaps. They say you don’t have to gap them but almost every one of my AC Delco plugs I bought from Rockauto were gapped at like 15-20, instead of 40. They tell you to return them and purchase new ones but that might take a while, with how many are not correct.
And BE CAREFUL when doing so. You can't check and adjust them like you would with an old school copper plug with the fat and sturdy electrode. Really, just avoid touching the electrode beyond a very light rub with the feeler gauges. DO NOT pry against the electrode to open the gap.
I'll take this opportunity to say that I've never had an NGK plug not gapped at its advertised spec.
Onlyone
New Mexico
Yep. just lift up on the tip lightly until you get it where you need it. It’s not hard to bend it.
Dustin Jackson
I really thought my Tahoe was gonna be fast asf when I got it idk why
Tahoes are one of the most heavy vehicles on the road, and slow as balls because of it but once they get up to speed its like riding on a cloud and that's where they shine.
The nearest freeway onramp near my house is a 20mph cork skrew onramp and I nearly get ran off the road every time I need to use the freeway because I have like less than 1 football field to get from 20mph to 70mph merging speed after the cork screw and sometimes the semi trucks don't have room to move over for me.
Marky Dissod
If the engine lasts 20% longer, you're coming out ahead.
It almost never is. It's somewhere between E51 & E83, depending on where in the country, as well as when in the year; ethanol will never start up or warm up an engine as well as gasoline.
donjetman
We had a 2002 flex fuel surburban and when I used E85 it was hard starting and I could tell the starter and battery wouldn't last near as long so I only occasionally ran it.
johnsonwillie199
