2009 Yukon Denali 6.2 L9H Engine Replacement
I honestly want to save this truck. I can figure out paying half cash and financing the other half or something. I just want definitive answers and it’s been tough. My first month of ownership has been taking this thing to a different shop every week lol. I’ve been getting rebuild quotes and if I can get a motor installed for around $6k-ish I would do it. A lot of the quotes I’ve gotten are much higher than that. Trying to keep my hopes up and maybe I’ll get a good quote for a rebuild and get that done ASAP so I can start finally enjoying this truck with my family.
Did you put the extension in your ear and look for the source of the noise? It sounds exactly like what happened to Mike and if that's the case for you, it's a relatively easy and inexpensive fix compared to overhauling or replacing the entire engine.
Careful with those low dollar estimates, know exactly what you're getting for that.
KraftMatic87
KraftMatic87
I have not tried to specially pinpoint what is making the noise. The last few mechanics said it sounded like a rod knock but I don’t know which one or whether that is even 100% true. I know lots about cars but I’m no mechanic and I am trying to find one I can trust AND who can do the work for me.
KraftMatic87
KraftMatic87
Here are some more videos of the truck driving:
Cold start:
Driving Up Hill:
More Driving Around:
You can clearly hear some kind of noise under throttle just trying to figure out whether this is really worth worrying about or should I just change oil and send it lol.
B-train
I'd say it's worth worrying about. That's not normal. I've had bad piston slap before, but that sounds more metallic.
KraftMatic87
KraftMatic87
Kinda was my instinct as well. I am bracing myself for confirmation that I’m gonna need a rebuild lol I know that is not a good noise.
Cold start:
Driving Up Hill:
If you keep driving it, it's going to drop and a valve is going to kiss a piston which could create quite a mess, like a bent rod, busted piston and then it gets all chewed up in seconds and debris goes all through your motor trashing the whole thing. Mike was barely moving his when it let loose.
I had an exhaust leak once that sounded similar, thought it was a rod knock too. Then I got out my mechanic's stethoscope and located the source to my great relief. I'm the type that thinks of the worst scenario when something goes wrong with my car. Thankfully the guys here steer me straight.
That sounds like valvetrain. Seems it’s a higher pitch than a rod, at least from a video.
Yes! All the rod knocks I've heard were more manly! Then when Mike posted his old videos he called it.
Hopefully the OP leaves it alone and calls LT on Monday morning. Then if he'll take it in, tow it there to be on the safe side.
KraftMatic87
KraftMatic87
I haven’t driven it in over a week. Funny thing was I had an exhaust leak on drivers side manifold. Replaced that and that’s when I noticed this separate knocking noise. I definitely would like to get it towed somewhere for sure I have AAA and would rather not damage it further if I need to have the engine rebuilt.
petethepug
Michael
SoCal
Why not do the L94 swap from a 6.0L gas 3/4 or 1T. They run on regular and later motors run on e85 too. Add a cam before you slap it in and you have 400+ hp and a low end tq monster with NO AFM.
KraftMatic87
KraftMatic87
My motor is an L9H and did not have AFM / DOD from the factory. However I have gotten quotes for a 6.0 swap and they are more readily available than the 6.2. I didn’t think about the fact that they run on regular gas that actually would be really nice. If I can’t save this motor then I’ll get a 6.0 they are usually cheaper than a 6.2 and have more availability.
petethepug
Michael
SoCal
I’m L9H in our Esky. The L94 swap is on my radar for long term solutions because L9H with up to 200K mi are going for $6-$8k.
Save your L9H and sell it documented and diagnosed for what’s going wrong with it because NO One else is doing that. They’re going to refresh or rebuild it anyway on a motor that doesn’t run and removed.
You can also keep it and rebuild it for a back up motor. They’re worth a mint.
KraftMatic87
KraftMatic87
Sounds the same as Mike's.
Lawrence Tolman from Powernation TV has a shop in your area now, Colorado Springs.
LT knows LS motors forwards and backwards.
I just emailed Tolman Performance. I didn’t see a website with a phone number but I did send LT a quick DM on instagram seeing if his shop can help. There is another shop very close to me called Colorado Performance & Repair in Northglenn who a friend said I could try as well and they have a great reputation for doing engine rebuilds. Thanks for the tip.
KraftMatic87
KraftMatic87
I guess it all depends on whether or not I’m gonna need a new engine. I haven’t dropped a valve yet but I’ve had quite a few people here and on different forums say that their truck has made the same noises and then dropped one. I’m hoping I can get it towed to either LT or somewhere else next week and get clarity on what’s going on and how much I’m gonna need to shell out to get this back on the road.
Geotrash
Dave
Richmond, VA
Hey everyone, I bought a 2009 Yukon Denali XL a month ago with 143k miles. It has the L9H 6.2 that did not have AFM / DOD from the factory which is why I was so excited about this truck. Unfortunately for me the pre-purchase inspection I had done for the vehicle conveniently missed many thousands of dollars in repairs. I’m trying to see if I can salvage the situation. After a few days of owning the truck I determined on my own it had an exhaust leak on the drivers side manifold. Replaced that and then I heard a knocking noise near the oil pan. I’m afraid I bought a truck with a motor that’s on its way to self-destructing.
After finding that rod knock I took the truck to several shops that told me it is indeed time for a rebuilt or replacement engine. In addition to that I have a leaking oil pan and trans cooler lines, and a broken CV axle on drivers side that needs replacing. I have attached two videos of the noise at idle. This is after the engine has gotten to idling temp.
Here is a more thorough inspection report I had done AFTER I bought the truck.
https://shop.tekmetric.com/inspection/W1ITrcRe8c1o1Zkx7uuIxQDwqrd76pPA2XVCsstIorw
Trying to see if I can even afford to keep this truck after an engine rebuild. I have kids and this thing was supposed to be our weekend travel vehicle for road trips up to the mountains. Now I’m afraid to even drive it around town to pick up kids and groceries.
I’m looking to see if anyone can help recommend a good shop in the Denver, CO who might be able to do a rebuild / cam swap. So far my best quote came from a shop in Goodland, Kansas that is 3 hrs from my house.
I love this truck and it drives great (for now) but this engine definitely sounds like a ticking time bomb. Looking for any guidance on how I should move forward or if I should just quit while I’m ahead and sell for a loss.
Thanks for the suggestions!
100% NOT a rod knock. The frequency is half crankshaft RPM. Valve train for sure.
If it were mine, I’d pull the heads, have them reworked by a competent shop, replace all lifters and get a good look at the cam through the bores. If any damage noted, I’d put a cam motion stage 2 truck cam in it (3-bolt) and call it a day. Actually more like a weekend :).
KraftMatic87
KraftMatic87
I’m hoping for the best but preparing for the worst! I’m definitely going to get this thing on a flatbed sometime this week and have it sent to a shop since it definitely needs some kind of major TLC. I’d be pleased if it was just the valve train. Hopefully cam isn’t damaged but it would be nice to throw an upgraded one in there. I stopped driving it a little over a week ago when I started noticing the knocking noise after I replaced a leaking exhaust manifold.
I’ll feel a lot better once I can get a final diagnosis on this and get a date when I can get everything rebuilt and repaired. Staring at it sitting in my driveway and not being able to drive it kills me lol
My daughter is going to do the same thing with hers, not waiting for the unknown to happen, planned availability do it on her times and keep on truckin'.
KraftMatic87
KraftMatic87
Wish I was as mechanically inclined as your daughter! I have two young kids (2 and 4) and I work full time and travel for work every two or three weeks. I just don’t have any spare time, especially over a weekend, to take my engine apart. If I knew someone else who knew what they were doing and could help me I could pull it off, but this is definitely something I’m going to leave to the professionals.
Ossipeelake
