oil dipstick
Conky105
Leduc Alberta
Call me crazy but when i change my oil and i go to check the level on the dipstick after I'm done with the first start up i have a huge problem seeing it on the dipstick. the oil is do clean its invisible on the stick!!! I also measure it out to 9 quarts. is there an aftermarket dipstick i can buy that would help me out? tks in advance
i forgot to add that its a 2019 yukon 6.2
Tuscan Ranch
Use a handheld light source like a pocket LED flashlight to see oil reflections or check it outside in the sunlight.
B-train
I've experienced that for years on generators that run on natural gas and use synthetic oil. Sometimes it's almost impossible to read it right after a change - the oil is THAT clean.
Sounds like you have a good clean engine and are using a good quality oil. I always use the light trick. Sometimes you can get a glint of light off it and it will show you. Or, look at it in a shadow with brighter ambient light as the background.
Lastly, not to tell you what to do, but I believe 9 quarts is too much oil. I could be wrong, but my 2017 6.2L takes 8 qts. Initially they were 8.5qts from the factory, but GM revised it to 8 qts. Again, probably trivial in the whole scheme of things, because it's technically only 1/2 qt over if you go by the OE spec I guess.
Multnomah Falls
Military
If I cannot read the oil level, I have just turned the dipstick to a different angle in the light of day and can read it. Maybe I should just use a miner's helmet.....
Off Road Pedia
