blueinkd
DOES anyone have the part number for replacement grommets for the intake bolts?? Bolting back the stock manifold and the grommets no good on some bolts. Tired, been a long day and google yielded inaccurate results
Get yourself a 3500 flatbed. On a serious note, what is wrong with it?
I finally replaced the master cylinder, now the rear driver's side brake line is leaking where it mates into the line that goes into the caliper. I tried tightening it but the leak just got worse. I'm letting the mechanic who originally did it, fix it.
nonickatall
Germany
I gotta say.. honestly…? I think I’d rather the snow than the rain…
And like the Jamaica people say:
Rain is liquid sun.
Nothing is more exiting, like walking in a warm summer rain, with your 27 year old beautiful love, when you just realized that the penny stock you bought to check your new bank software, just make 1 Billion dollar, because they developed a medicine which can heal cancer..
Ok, the only problem is, that you always wake up in those dreams and still have the same old problems... :Big Laugh:
ncalvo
FL
RAMurphy
Bob
Military
S. Maryland
Driving back from work Thursday evening, I heard a scraping/high freq wine on the driver side rear wheel. So on Friday, I jacked up the rear and pulled the tire. Took the caliper off and discovered the brake hardware failed and slid towards the disk. Caught it early so no damage to the disk. However, the hardware needed to be replaced and since I needed to do that I replaced the brake pads. Since I had it jacked up, I decided to pull the disk and adjust my parking brake (finally). Wow, I forgot how hard it was to get those two 18mm bolts out. And since I was that much into it, I ended flushing the brake fluid with my home made brake bleeder. Started with the passenger side back wheel, drivers side back wheel, passenger side front wheel and finally driver side front wheel. 3 quarts of new brake fluid and all the old nasty brake fluid has been replaced.
blueinkd
Got all it ready to drop back in. Just need a hand from my buddy who helped me pull it. Came down with a bad stomach bug and I don't have it in me to try it alone. Don't mind the dirty from cover, the seal is new and all gaskets
Gmg0547
Changed out the passenger front brake hose that was cracked. I think it's safe to say the fluid is original. The pedal feels a little better now. Thanks @vietvet for some assistance.
At least pull that temp sensor before you go to drop it in. Things move out of their way to hit those and break 'em.
blueinkd
I also added the shorty tsp headers on it before she went in. We took our time and had the hoisy literally dropping centimeters while we both guided each side. Disconnected heater hosed to keep them from being damaged or hung up on something.
mattbta
Frisco, TX
Received the K5L fans in a day and a half. Cleaned them up, installed, tested with Tech 2. Will drive it later and keep an eye on voltage. Haven’t put the Mechman in.
There’s a slight difference in the housings, the K5L have a couple spots for something to bolt into it on the right side or to bolt to the radiator. Little bit of contact with the throttle body coolant hose. I’ll keep an eye on it.
Hit mid 90* temps over the weekend and got to see these beast fans in action. The 700w draw is too much for my comfort on the 145a alternator when on high speed. Looking around, there is a 160a available in the model these fans came from (2009 Sub). It seems logical that on a K5L vehicle, it might also have the 160a.
Ordered the hydraulic crimper, some battery bolts, lugs, and 1/0 OFC so I can put the Mechman 240a in.
Got a little more serious about figuring out my left front clunk when turning. Found a toe adjustment nut not even finger tight on the left side tie rod.
Didn't fix the clunk. Might be time for tie rod ends - been at least 10 years. Now, do I go full send on some Rare Parts fancy ones? I don't off-road my RWD so probably wouldn't realize the benefit, but ¯\_(ツ)_/¯
ASG-MikeS
