Question: Is there a video walk-through for installation of Bilstein B8 5100 front struts re-using OEM spring/spring perch
OhioYukon
I'm wondering if anyone might be aware of a good video walk-through for installation of the Bilstein B8 5100 front struts re-using OEM spring/spring perch? I've been looking for just such a thing but no luck. Trying to quickly decide whether I want to attempt the install myself or pay a shop to do it when I'm have the front lower ball joints replaced under warranty here shortly.
Thanks in advance for any input.
Dustin Jackson
I could write you instructions on it but if the shop that is doing the lower ball joints has the equipment for this it could be very cheap to have the shop do the springs as well.
If i recall correctly the bilsteins come with written instructions
Charlie207
LFOD, New Hampshire
I installed a set of 5100s on my Armada, and it's basically 99% the same procedure. You'll want a spring compressor ( I rented this from AutoZone: https://www.autozone.com/test-scan-...strut-coil-compressor/537058_0_0?cmpid=OSA:US), and big impact gun.
Also, find your best safety squints, and have your mother on speed-dial in case something goes sideways.
Remember, the deadliest springs are the things that don't look like springs.
man, I was just watching a video the other day where the guy is using a spring compressor and somehow did not have it on correctly and he loosened the bolt on the spring cap and the spring expanded some and snatched his finger in it, somehow he was able to use his other hand and tighten the compressor but geeez man no thanks
Charlie207
LFOD, New Hampshire
man, I was just watching a video the other day where the key is using a spring compressor and somehow did not have it on correctly and he loosened the bolt on the spring cap and the spring expanded some and snatched his finger in it, somehow he was able to use his other hand and tighten the compressor but geeez man no thanks
The only safe spring compressors are those giant phone-booth sized contraptions with safety cages around it. Even then...
Conedaddy
