Trasmission leak at output/prop shaft
77mercury77
I just got my truck back from a rear main seal replacement and now i notice a trans leak at the output shaft seal.
I figure this one is easy, just disconnect at the u-joint, pull out and replace?
Are there any special tools, consumables, other things I should replace while i am in the process?
Also am i going to lose a lot of fluid or just need a top off?
tom3
You have it figured out about right. Not a lot of fluid back there normally. I always try to put the drive shaft back in just like it came out, mark it at the rear. I'm pretty ocd though.
NickTransmissions
Sin City
The transmission bench
No special tools, just a 7/16” wrench or socket/extension for the driveshaft-to-pinion yoke bolts. Like Tom said, index the driveshaft with a paint pen or spray pain so it goes back on exactly how it came off (though you’ll know it right away if you put it on the “wrong way, lol”).
Use a big socket and hammer to install the new seal. Some folks will put a thin coat of rtv on the outer surface of the seal body. Coat the sealing surface with trans fluid or petroleum jelly before sliding the slip yoke back on.
mattbta
Frisco, TX
Not sure if NNBS are the same as NBS but a shop installed a 4x4 output seal on my RWD after doing the rear main. They are two different parts. After convincing them it was the wrong seal and they put it in a lift and ran it to confirm the noise was in that area, got the proper seal on.
Watch your ears for the horrible noise that resulted:
NickTransmissions
Sin City
Geez, sorry to hear that (figuratively and literally)! Glad it got fixed and hope no other damage of any kind was done.
Did they/you check the slip yoke for any grooves cut into it by the wrong seal being installed?
mattbta
Frisco, TX
I should, forgot to inspect when I had it off to grease the splines. Would think it would have been obvious if so, but I don’t remember anything. Seems fine, so far.
What year and is it RWD or 4WD?
77mercury77
Job is fairly easy to do.
I got lazy and did it on the ground with out lifting the rear wheels.
Some advice that wasn't stated above:
-I took the seal to the hardware store and found a PVC plumbing fitting that was the right size to help drive it in.
- I needed a 11mm box or crow's foot for the rear bolts. A socket is too large and I had clearance issues.
-Tape the u-joint with masking tape to keep the bearings together. If they drop you're not gonna have a good time.
BadDaddy2003
