Every other day something folks! Water pouring out of the HVAC vents over passenger seat driver side
MassHoe04
Western MA
This thread shows where they come out and suggestions on what to do and not do...
The video in the thread removed the door. Probably don't need to do that, but I thought it would help you see where the drains are up top and where they come out.
The other comments might help with how to clear the lines (carefully- seems to be the main theme).
T
tomloans
This is great but my front two are not clogged. But this gives me and idea to look at the back two doors as well to see where the weep holes in the back are. I will look around. It looks like the headliner may have to come off for the back two. But maybe not. We will see.
Super Moderator
Elev 5,280
If you can get to either end of the drains, you could use a long piece of weed whacker line to see if the drains are clear.
MassHoe04
Western MA
That looks like a good suggestion to clear the lines without damage.
If you open the sunroof to vent (tilting the back end up) maybe you can see the drain holes at the back corners of the perimeter drain collection pan (or whatever that thing is called).
Snowbound
Jim
Chicagoland (Lockport)
There are drain holes in the rear as well as the front. I soaked mine with WD40 and then used low pressure 30psi max to blow the lines clear. Heard a lot of stuff blow out. Fronts blow into the cowling area and rears blow down into the B pillars down into the rockers. Used to have a schematic somewhere showing them but can’t find it now.
MassHoe04
Western MA
Should be easy to find the rear drains on mine... My rockers have the optional road salt access panels!
