2015 Tahoe/Front hitch installed !
Joeltz
Front hitch installed straight to frame
Hitch receiver hole comes out just right205432A5-26B9-40B8-AF21-B408262F23F8.jpeg41C9DDA6-4565-4C8C-9F8C-9173E97F9E8E.jpeg
B-train
That's pretty slick. I had thought of that for my 2008 to use as a winch mount, but the ones I found all seemed to hang super low. What is the make of yours?
Joeltz
Joeltz
65064 draw tite… but all you need is cross tube with mount hey B do you know how to delete pictures her at Tahoe Yukon ?
Super Moderator
Elev 5,280
Open your post with the EDIT button at the bottom, then click on the trash can for the pic you want to delete:
Then click the SAVE button at the bottom.
Joeltz
Joeltz
Thanks…. The tough part on my 15 Ltz was getting hitch at Useable height and the look that is right . I realized the 2 1/2 square Main tube had to mount directly to the frame and the 65064 draw tite had brackets I cut off and mounted it far enough foreword & Upside down to have receiver tube Just barely touch the backside of the plastic center part of bumper… It was crazy doing without being up on a lift….. To figure the custom fit - My idea was to fold up a cardboard box to be 2 1/2x 2 1/2 x 36 long and “ Find your fit for the 2 inch inside receiver tube to measure to grill plastic for the receiver part the hitch fits into.
By Chevy luck it lines right up with a small “up Angle” I bought the Hith kit off e- Bay and by Looking at all listed … like the 10th one said USED And looking closer it was a company that buys back box damaged goods & it mentioned product used Or BOX Damaged !! $90 NOT 210$
I said .. will buy if bolt kit included ( its $39) Free freight never installed box damaged only & was here in 5 days
& for 90$ a good deal !!’ So look deep for this place altogether I have 90$ + 12$ of saber saw blades & a Ruined Makita grinder that jammed up under there and flew around inches from my face. Yes I had to saw off the Frame shoe and drill 2 - 1 inch holes in frame…. The heaviest I will load it will be my cycle rack and Yamaha scooter.. about 200 lbs…. I wanted it to be able to push my 18 foot boat in the garage.. by myself with my Tahoe . Write back with any questions
Joeltz
Joeltz
Looks good to me I have 5-6 different hitch inserts for various reasons . Did a little tweaking to rear hitch also
Blackcar
I see you received your umbrella from truck legends received mine last week.
