Can receiver hitch be removed off of a 2007?
GCP_2004
I want to have a corvette style exhaust run out the back, but I need to know if the receiver hitch can be unbolted. I also have the rear lowered 4 inches so how could I have it run for best clearance? Thank y’all!
Sir_Hiro
Automotive Mad Scientist
Yes. There is 10 bolts on the underside. You will need to remove the bumper to get them out.
Depending on how rusty they are you might want to have a sawzall or cutoff wheel handy. Those welded nuts have broken off on me before.
But its a pretty straight forward process. I just did it on my Yukon.
3 Big ones on bottom side are 21mm and the 2 side ones are 18mm IIRC.
The best way imo is removing the spare tire and routing the exhaust through the Hitch hole that would be there..could give you a bunch of clearance.
GCP_2004
GCP_2004
Thank you very much!
CRN_25
