What is it with you and signs? :happy175:
there is a independent Verizon store right there and they have 3 (movable) mobile pickup signs #1-3 that they just leave in the way 24/7, one of these nights I should just go over there and toss them in the dumpster. For one they are not busy enough to need 3 mobile pick up signs and for two they could just put them up OFF the curb and out of the way of people parking. :893Chainsaw-Smilie-
St. Louis
They probably have those spots in the lease contract as their spots and people other than their customers parked in them all the time so they have those signs like that. I see it all the time in the smaller shopping strips around here.
You don't know their story
But hey, if messing with someone else's property makes you happy...
lol, i'm mostly just kidding but they are annoying and they could put them up on the concrete so you can actually park and not have your @ss sticking out 3ft
When I was a young whipper snapper I woulda just moved them to a different store in the same strip mall just for my own amusement. I'm WAY too mature for that now, though.
Charlie207
LFOD, New Hampshire
Oil change just now, and since I had read about it I pulled out the oil pressure sensor, screen, and saw a bunch of gunk stuck in the little filter screen. Tossed it in the trash.
Reassembled everything before finishing the oil change.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Did you replace the screen??
Charlie207
LFOD, New Hampshire
No. AFM is disabled, so it's not needed.
Also, I poked a hole in it while removing it with a hook. I've figured out a decent system, and can have the sensor out/back in pretty quick.. 5 mins or less.
I had read that engines without DoD/AFM didn't have screens.
89Suburban
SE PA
Ok good deal. :)
That screen isn’t really needed regardless. In fact, that screen prevents the sensor from reading the true psi of the oil pressure. Friggin stupid design
RooTBeeRthe1st
Stared at the factory idiot gauge and the digital readout on my head unit during warm up this morning.
Not even sure why they put numbers on it if it's so far off.
And I think it stays at the 210 Mark between 180 and actually about 200-210 but I'll have to check that when the temps are a bit warmer since it wouldn't go over 180 this morning.
Charlie207
LFOD, New Hampshire
I don't understand why they use idiot gauges, or don't allow for real-time readings in the info display screen.
I suppose the idiot gauges are to prevent people from freaking out, but it's certainly not helpful for monitoring actual engine conditions.
Sparksalot
Bastrop County, Texas
I watch my Scangauge and have noticed the same.
As somebody here said not long ago, perhaps it's to keep the soccer moms from freaking out too much.
It's intentional so folks don't freak out and fill up the service bays.
jared999
Pulled the sunroof glass to replace seal. Old Seal had some tears. Permanent glass seal looked good, thankfully.
All in all, about 40 min to do the job. Using a silicon spray is a BIG help when putting on new seal. Stealership wanted about $300 in labor to do this.
Dirt was in the permanent seal wrapped around glass. Lots of dirt.
Escalade2007
