Service Hybrid System 2009 Tahoe
Istvan
Hello Guys
I have a 2009 Tahoe Hybrid. The service hybrid system came up a while ago, but no Check Engine Light. Scanned it, and it came up with internal fault in the Serial Data Gateway module. Changed the Serial Data Gateway module, and know it comes up with High Voltage Impact Detection Sensor 2 and 3 fault, but no airbaglights. Unplugged the sensor’s, looked good, the airbag lights came on. Plugged the sensors back, no airbag lights, but the Service Hybrid System message, and the fault code still there.
Fault code is:
B0083-39
B0084-39
My main problem is, that I live in Europe, so no GM services unfortunately. Anybody any idea? I would really appreciate some help. Thanks a lot.
BG1988
those have to do with the air bag sensors the ones under the plastic skid plate 2x most likely faulty?
i'd replace both of em
B0083-39 left Front Impact Sensor Internal Electronic Failure
B0084 39 Right Front Impact Sensor Internal Electronic Failure
check the harness for damage DISCONNECT THE BATTERY or you risk setting off the air bags wait 15min to drain any capacitance current still in the system you can check the cables for any capacitance with a muti meter
I
Istvan
Thanks you for your reply.
Sorry but the exact code is:
B008A-39
B008B-39
High Voltage Crash Impact Detection Sensor 2
High Voltage Crash Impact Detection Sensor 3
Is that telling you anything? I have not programmed the new Serial Data Gateway Module, just plugged it in.
j91z28d1
B008A-39
B008B-39
ahh those codes show totally different. but my software doesn't have the dash - 39 at the end so don't know about that.
sounds like you need to program that module? no clue how you do that outside the country.
I
Istvan
Yeah, that’s what I thought, I need to program the SDG somehow, then the Sevice Hybrid System message will disappear. Thanks a lot for your time and help. Really appreciate it. Thank a lot.
Might have to get it done at GM dealership over there. Or somehow have TDS think you are in the states. Need MDI with laptop to program and subscription to ACDelco TDS for programming.
I
Istvan
Unfortunately no Gm dealership, to be exact, there is, but not like over there. Only European models, which is Opel-Vauxhall…
I might be able to find someone, who is able to program it, but that’s the hard part. It’s the same shit always, a had an 89 IROC-Z, and a 96 Fleetwood, but it was hard to find someone, who really knows these type of cars and has the proper tools… But I simply love these cars, so always will have one, even if they give me a headache sometimes
j91z28d1
how do you end up with them over there? I've always had a soft spot for the old 3rd gens. I saw a pic of one one time from a city in Italy I believe it was. always wondered how they end up there and thru the hard licensing and registration
I
Istvan
Well, there is always a few dealers, who able to ship them over, or a few people who brave enough… Registration is hard and not always straightforward, but obviously we taking the risks, because we love these cars. I lived in the UK for about 7 years I bought the Cadillac and the Iroc-z in there, then moved home to Hungary. I sold both cars, then bought this big boy. It’s hard to live with them, because there is no European specs of these cars, there is a vehicle inspection every two years by law, except 30 years old cars or above. So legally these cars as you see them on the roads are not legal in Hungary, need to change the lights and some other things, depending on what car is it.
j91z28d1
very interesting. I've got friends that love all the Japanese cars and always want to bring them to the US. I guess they need to be over 25 years old and some of the cool ones are just getting to those years. so prices have gone up a lot.
luckily it seems to be a fault that it will still run and drive with. swath diver above understand flashing the modules yourself at home, I've never done it and it seems it might be limited by country. I wonder if that's something a good VPN could make work.
these trucks are so rare over here these days, normally what has happened is a fairly minor failure, owner takes it to a gm dealer. dealer mechanic has never seen them before, doesn't want to work on it. runs up a bill doing some basic diagnostics. tell them they either can't fix it, or it will cost more than the truck is worth. so owner takes the loss and dumps it by trading it in for something new.
it's a shame really. when they work, they work well and seem to go 300k miles. so while you have zero support, we don't have great support over here either. these forums are these trucks best hope of staying running.
I
Istvan
I have tracked that this hybrid drivetrain is in some BMW-Mercedes 2010-2011.
So if I’m lucky, I might find someone. I always try to do my best, to keep them on the road. Only selling them, if I can’t afford them or need the money for something else. Thanks for you help, I will let you know what’s hapening.
BG1988
transmission is different shape though
T3xasR3dRum
The transmissions in these vehicles are actually modified Duramax Allison Transmissions, which are very reliable. One thing you're going to notice me saying repeatedly on this forum is that the batteries will be the issue 99% of the time with any check engine light. It's really sad that dealerships have absolutely zero knowledge about these hybrids, because I believe they are some of the best vehicles Chevy has produced in a long time. If you ever get a chance to work on one that's having issues, the first thing to do is check the voltages on each individual cell. Not one can read lower than the others; they all have to be the same. After doing that, if it all checks out, then you should proceed with the information the codes are providing you. I can guarantee that the battery is the issue.
RicRac
Hi, did you find out what was the problem with the service hybrid system message?
BadDaddy2003
