Let's see some pics of some lifted and leveled
992dr
Eastern N.C.
It's a work in progress but I roughed in the skid plate without a bottom bracket support. It's just bolted on top. First pic is skid attached. Second is without from a distance. Still trying to decide on grille options.
Very nice, I agree with the skid just finishes it off. I'm debating about building one for mine out of tubing just for sh*ts and giggles
Key Level + Shock Brackets, 2009, 2500
39.25” at the top of the well
Where's the damn drooling emoji GMT900 2500 SUV makes me tingle in my lower abdominal area.
Jimmit
Hahaha. Trying to decide if I just put a grill guard on her or do a bunch of modifications to put a full RanchHand front end… ugh. It’s like a $4000 swing, but I think it would look killer with Silverado fenders, 2500 hood and a legend series bumper… meh. We shall see.
2DRLML_93Yukon
1993 Yukon
2011 gmc 3500hd LML ppei tunes
6L1000 Allison ddp A50
MP1625HD transfer case
AAM 1050 rear end
1993 3500 front differential
1993 3500 spindles and hubs
20x12 35x12.50
olyelr
Elk Rapids, MI
Sorry never seen it before…but is the valve stem on those wheels on the inside of the wheel?
jcsswix
Fox 2.0 Front/Rear lift
Dobinsons 2" rear lift springs
Method Grid MR309 Wheels, 20x9, 6x5.5, offset: +18, Backspace: 5.75 MR30929060518
Nitto Ridge Grapplers 295/55/r20
Cognito 110-90295 upper control arms
MOOG CK620956 Heavy Duty lower control arms with problem solver gusher bearings
Mevotech TXMS50820 Heavy Duty Terrain Tough stabilizer bar links
Baseline Overland roof rack
Baseline Overland front winch bumper
Jimmit
So… I went under the truck the other day and my UCA’s were at a terrifying angle… lol. And… After driving around post level, the front was sitting just high enough to be visibly higher than the rear.
Sooo…. Replaced my upper control arms with some Cognito’s, front shocks went to Bilstein 5100’s and I put a 1” spacer under the rear springs.
Now she’s about 40” in the front, 40.5 in the rear. All the angles in the front suspension look /so much/ better. Is it safe to assume I need to get another alignment? Lol
randeez
south florida
How'd you guys with cognito arms bolt on the balljoints? Mine came with 5/16 hardware, the UCA is only slightly bigger, but the balljoint has a 3/8 holes and the 5/16 hardware just swims around in there pretty loose. I don't trust the clamping force of the hardware to keep that balljoint from shifting around. I'm going to drill out the UCA to use 3/8 hardware through all of it
jcsswix
I have not had any issues and I've had them on my rig for 4 years now. I have tested the suspension on many trails and whoops at high speed. With the lock nuts and some loctite you should not have any issues. I went out to check today and they are all still tight.
Jimmit
I just followed the manufacturer instructions. 22 ftlbs on the 5/16. I’m going in for an alignment today then I’ll torque everything down this evening after an hour cruise and then again at 300 miles… I wasn’t super impressed with the fit on the cognito UCA’s, passenger side almost seemed too wide- and I had to do more modification to the brake line bracket than I expected.
randeez
south florida
yea i wasnt thinking it would come loose. my concern was more if you torque it down say at the outside of the pocket, alignment, yadda yadda. stuff the tire and it pushed the balljoint a 1/4" back into the pocket. i just wanted to have no room for the ball joint to be able to move around. drilling the uca out to 3/8 and using 3/8 hardware the bj cant slide around
Jimmit
We’ll post alignment, she rides sweet. Apparently my eyeball alignment was… meh. Camber was spot on, but toe was off the charts and caster was like 6.5 lol. She’s still “out” on caster at 4.5 but we decided equal caster on both sides was better than one side at 4.5 and the other at 3.7
JJ351
CA
Finally got some good weather to figure out a solid solution to the bottom skid plate mount; M8 stainless nutserts, 50mm stainless M8 bolts, and 25mm stainless spacers. In the meantime, I'm thinking a wider aluminum skid with 5 inch fog lights.
992dr
Eastern N.C.
Damn, THAT looks a gooooooood
I like the plans for skid and fogs
You need post more pics of your ride :)
Raptor Tahoe
2007 Tahoe LTZ - 37x12.5x20 Mickey Thompson tires on Black Rhino Armory wheels, Rough Country 8 inch lift, 4.56 gears and HD axles, Amerihood, TrailReady bumper, KC and PIAA lights, ARB roof rack, Raptor paint, Bushwacker fender flares, Royalty Core grille, Kooks headers, Warn Winch, dual Optima batteries
MonteJ
