exhaust smell in cab '21 denali
steiny93
Anyone getting an exhaust smell in the cab?
Wife's '21 denali, first time in the cold weather (-20F) we had an exhaust smell in the cab. Dealer worked on it, said something about a bad check value, (and it got warmer outside) smell went away. Now this winter (-20F) it's doing it again.
It only has the smell when the vehicle is barely moving or stopped with a breeze from the rear.
It isn't the regen smell, it's a very smelly diesel exhaust smell. Imagine a JD 4430 starting at 0 degrees in a pole barn, that's the smell and you'll get it for a whiff then its gone for a minute or two then happens again.
Anyone else?
It goes in again this week for yet another warranty visit, confidence waning.
Holy Roller
That’s exhaust odour before emissions treatment. Either at first start up - or your leak is somewhere near the engine itself.
S
steiny93
That is an excellent point; the leak has to be hyper early in the exhaust system.
This smell isn't at startup, I've only noticed it after the vehicle is up to temp and being used (drive throughs, stop signs, off road low speed, etc).
S
steiny93
nothing lit on the dash, I haven't plugged in a scanner to see if their are any pending codes
The techlink of 14365 is what 'I think' they did last winter, I got the intel from my wife who got it from the service writer (3 layers of misdirection :))
Larsonxjs
Anyone else?
I’ve gotten a little smell as well using the remote start to warm the cab.
By the way this is poetry - “Imagine a JD 4430 starting at 0 degrees in a pole barn,” few people will ever experience that.
S
steiny93
UPDATE on the original issue
Dealer just called, turbo is bad, they have requested a new one which happens to be a 'direct ship' only component. No ETA as to when it will arrive, dealer said to expect weeks, likely not months.
They don't offer Denali's or any full sized suv's as loaners while this is being figured out. Not impressed to say the least.
dbphillips
That’s worrisome. Ours is doing something similar, but also a lot of smoke at startup.
S
steiny93
If you are getting exhaust smell in the cabin, take it in, their are a few notices out (notice the 3 listed towards the top). The dealers can test for leaks pretty easily.
On this Denali, the amount of smell in the cabin seems to depend upon the temp of the vehicle at startup and if you have the hvac in recirculate mode or not. Recirculate mode helps alot. If the vehicle is cold (< 10F) the exhaust smell is much stronger then if the vehicle is say 50F. So, this one always sitting in a heated garage, the frequency of stink was low; but leaving it outside over night; it'd be near undrivable until it was up to operating temp.
S
steiny93
UPDATE AFTER LATEST FIX
Dealer received the parts and put them on the truck (Wednesday), they drove it and tested it a fair amount ~20 miles.
We picked up the truck, exhaust smell gone.
Drove it about 10 miles.
Still getting exhaust in cabin during cold startup.
And...
Check engine light, service emission system msg, reduced power msg on the dash.
Truck is back at dealer, they are assuming a failed weld on the valve but will test to verify.
DuraYuk
And...
Just as I expected. They are guessing and have now introduced some other issues because of tech incompetence. It 'was' something simple to begin with. Now you have to fix the initial problem and the host of other things they may have messed up doing what they did.
I'm sorry these incompetent service departments are souring the ownership experience for you guys. The turbo diag in the beginning never made any sense.
Keep us posted. The few smells that were reported were fixed with a cabin air filter replacement.
S
steiny93
UPDATE AFTER ANOTHER FIX
Exhaust smell at startup and lots of service emissions, check engine, reduced power messages on dash.
Dealer had truck for a day.
On the side of the turbo lives a sensor which failed. This is the brand new turbo which they just installed. They had a sensor available so they swapped just the sensor. Then they did another leak test and didn't see any leaks, swapped the cabin air filter and are having us try that. Driven it a couple times, it doesn't smell.
DuraYuk
At least they are quick about it. They are gonna get charged back for that turbo lol.
Misdiagnosed. The cabin air was the fix. They have to write it up as something different so that it doesn't get labeled as a comeback.
Hopefully it stays fixed for you..good luck !
S
steiny93
The cabin air filter was ABSOLUTELY NOT the fix.
At startup, hood open, the exhaust smell was horrible. Their was 100% a leak in the exhaust system.
The outstanding question will be if the smell we got after the turbo replace was only from residuals in the filter. That I don't know, time will tell.
DuraYuk
At least it's fixed now after the cabin air filter was replaced ;)
Hopefully the techs story was written well enough to avoid a charge back by GM.
If the turbo was actually leaking into the engine compartment you would have messed up 02 sensor logic as well as other tell tale signs.
If your happy that's all that matters. And it's fixed.
Chad G 1979
I dont get how a cabin filter would make it smell like exhaust in the engine compartment with the hood open at start up.
As the cabin filter is inside the vehicle and filters air for inside the vehicle.
Yes after the turbo was replaced the filter still needed replaced after it had absorbed all the fumes from the engine from the leaky exhaust. So it still was part if the smell, but not the cause of the problem, just a symptom of the problem.
DuraYuk
If your vehicle is doing a regen you can smell it outside.
Im personally not convinced the turbo was leaking without the tell tale signs such as 02 sensor logic etc.
With that said I obviously wasn't there and don't know how the tech diagnosed it. A large visual leak would be accompanied by emissions codes and live data information.
The secondary issues leads me to believe there was more to it/misdiagnosed to begin with. Almost like a leak was introduced after the fact with the codes present and all.
The cabin air filter has been cause of some smells in the diesels. Not because of leaking turbos which is pretty damn rare in the baby max.
Regardless this is just online conjecture. Im glad OP got it fixed whatever the root cause actually may have been.
S
steiny93
I don't think you guys are understanding the course of events.
Issue 1: When the engine was running, exhaust smell happening in the cabin. If you got outside and opened the hood you could very clearly smell untreated diesel exhaust (not regen small). This was diagnosed as a leaking turbo via GM's smoke test procedure. (This exhaust was being sucked through the cabin air filter into the cabin)
Issue 2: After the turbo was replaced; continued to get an exhaust smell at startup (only in the cabin; for say 1 min). Tested the system for leaks, none found. They pulled the cabin air filter, it was stinky (from the previous untreated exhaust going through it). Filter changed, it doesn't smell now.
Issue 3: Check engine light, emissions, ect, sensor on turbo failed. They replaced the sensor and now those messages are gone.
A cabin air filter cannot be the root cause of an exhaust smell within the cabin. Changing a cabin filter will not fix an exhaust smell issue. Their has to be a leak in the exhaust system to get an exhaust smell into the cabin. (I'm not taking about regen smell, I'm taking untreated diesel exhaust smell)
S
steiny93
This part doesn't make any sense. An exhaust smell doesn't originate within a filter, the contaminate has to be pulled through the filter first.
DuraYuk
It absolutely makes sense as it brings in outside air. Could be any vehicle that contaminates it.
JasonW4141
