08 Yukon denali 6.2 engine. 28 psi oil psi at 55mph & 1300rpm. Seems low to me. Any input ? Thanks.View attachment 390169
It hits about 38psi when passing.Assuming the gauge is accurate, that's lower than average. What does it do at max RPM, like when passing? I say "when passing" cuz you can't rev it to max RPM/shift point in Park or Neutral.
Ok I orderd a new sending unit and screen today. No scan tool. I did jack the rear of the truck up as hi as my floor would go to see if the psi would jump because the o ring on the pickup tube would be submerged in oil & no change. I hope it's a bad sending unit. Thanks for the information.The ~10psi sweep from cruising to max RPM is mostly normal for these engines in stock form. You're just on a lower scale. First step before getting too concerned is to verify with a mechanical gauge. Might wanna have a new OEM oil pressure sensor to go back in while you're working in the area. Could be the gauge. Have access to a scan tool that shows live data? The PCM would report what the sensor is saying. So, if the scanner shows a higher scale than what the gauge reads, then you likely have a faulty gauge. If the mechanical gauge confirms the "low" pressure, report back and we can move on from there.
Then if no change, an oil change. I appreciate all the input.The O-ring test takes overfilling the oil or being on a really steep incline, more than what a floor jack would achieve. Either find a steep incline or overfill by 1.5-2 quarts and find a mild-moderate incline to be sure. I second @swathdiver's suggestion of trying a new oil filter. I never think about the oil filter causing low pressure but it is certainly a thing.
Well changed oil & filter this morning & I have 40psi again. I'm guessing somthing in the filter failed. Thanks everyone for the information, greatly appreciated !08 Yukon denali 6.2 engine. 28 psi oil psi at 55mph & 1300rpm. Seems low to me. Any input ? Thanks.View attachment 390169
Nothing failed. It happens. That’s how I can tell I’m due for a change beside looking at the OLI, my hot idle drops under 25psi. New oil and filter and it comes back to normal. Now you know, and knowing is half the battle!Well changed oil & filter this morning & I have 40psi again. I'm guessing somthing in the filter failed. Thanks everyone for the information, greatly appreciated !
I just had a similar experience, where my oil pressure suddenly dropped, but not quite as much as yours dropped. An oil change and new filter restored the pressure to normal. Strange, as I change my oil and filter every 3000-5000 miles. But, it did happen.Well changed oil & filter this morning & I have 40psi again. I'm guessing somthing in the filter failed. Thanks everyone for the information, greatly appreciated !
Yeah definitely strange. I change mine at 3000. Ive never had this happen. But I'm glad I dont have to tear into the engine to fix it.I just had a similar experience, where my oil pressure suddenly dropped, but not quite as much as yours dropped. An oil change and new filter restored the pressure to normal. Strange, as I change my oil and filter every 3000-5000 miles. But, it did happen.
Thanks man. I think I'm to go now.Ditto @Dustin Jackson . I usually see pressure in that range in my 2008 as well. 50 psi on startup, then drops off with temp. I replaced pan gasket and o-ring last year, same situation as you see. I'd say you're good. But, it doesn't hurt to check with software or mechanical guage if you are concerned still.
