No oil pressure at start up, 2001 Tahoe
Did the O-ring a few days ago only because I had the oil pan off to install a new oil pan gasket which was the original riveted gasket. Should of been done this fall when the weather was in the 60's but that would of made to much sense. The O-Ring was green and flat exactly like Chads. I also replaced the Starter with a brand new one before I put the Oil Pan back on. Had I known the Crank Sensor was behind the starter I would of got a new one of those as well. You can probably drop the starter down some and replace that sensor but it would of been nice to replace it with the starter completely out of the way. I did not complete this job in only a few hours the new starter itself took a hour as I had some problems installing it. Working upside down on a cold floor is not something I look forward to doing and if my oil leak is the main seal plate gasket I will still have the leak.
Hoping for the best.
JonnyTahoe
Minneapolis
Got a bit more oil pressure after installing a new (red) Oil Pump Tube O-Ring. When your starter bolts have oil drops on them it is from a leaking Rear Plate seal gasket. When you have oil dripping off every bolt like mine it's both the Main and the Rear Plate seal.
mattbta
Frisco, TX
Got a bit more oil pressure after installing a new (red) Oil Pump Tube O-Ring but not as much as I was hoping. When your starter bolts have oil drops on them it is from a leaking Rear Plate seal gasket. When you have oil dripping off every bolt like mine it's both the Main and the Rear Plate seal. When your going to Cosco once a month to get cardboard for your garage floor like I do you have more work to do than just a Oil Pan gasket.
That's where i'm at now. Told myself after the new year, I'll take it in for the damage. Maybe go beat on it hard and see if I can get the trans to go out (166k original). My luck would be paying for the rear main labor and driving home the trans grenades.
GBF1
My 04 Z71 has 245k. These trucks last if you take care of them. I have had zero oil pressure issues since I put the O ring in. hope this thread eventually helps someone avoid a very expensive "rebuilt" just because a $3 oring goes bad.
Any idea what a shop would charge for this repair? I have a 2006 Denali with 6.0
Based on what I'm seeing online, I would estimate $500.
Sounds about right. Alldatadiy lists 3.5 hours labor to install a new oil strainer which is what needs to be done to replace the o-ring. So figuring $125 an hour for an average shop rate, that’s about $400 labor plus the o-ring, oil, filter, pan gasket etc $500 sounds correct. It’s not terribly hard to do at all if you’re mechanically inclined and could save yourself $400 or so.
I agree 100%. I did this in an afternoon on my 2WD Yukon. If you have a 4WD, it will be a little more difficult since from what I understand you have to drop the front differential.
I just removed the 4 big nuts that hold the front diff to the frame, let it drop, and barely pried it down a tad more. A short piece of 2x in the right place held it down far enough to remove the pan.
Merc1973
Maryland
There is no need to replace the oil pickup tube. Just the O-ring is needed that's only like $7, including other costs like oil pan gasket and RTV sealer. So shops want to replace the pickup tube too or is that just what GM likes to do?
Not afaik. I didn’t see a listing for replacing the o-ring so I used the labor time for replacing the oil strainer which should be the same amount of time as replacing the o-ring since they’re basically the same operation. The parts aren’t a major expense here, it’s the labor especially with the hourly shop rate these days.
2006Tahoe2WD
Silicon Valley
Excellent writeup/picts/etc. Thanks.
I'm wondering what oil pressure numbers (hot/cold - idle/1000 rpm) indicate that changing the O ring should be considered?
JonnyTahoe
Minneapolis
I replaced my O-Ring last fall. Pressure went from just under 40 to almost 60 cold. Normal Operating Temp at 70 mph (2000 rpm) is exactly 40 psi. My rust free Texas Yukon is a 2WD. I wanted to remove the oil pan to inspect the condition of the lower end of the motor and the inside of the oil pan for sludge build-up. I got lucky everything was surprisingly clean. While the Pan was off I replaced the O-Ring, the Starter and prepped the bottom of the engine block for the new Oil Pan Gasket.
GBF1
For the past 45k miles my truck has had its oil pressure drop to zero, within 20-30 seconds after start up. It was not the result of a bad sensor as I tried replacing that first, besides, the loud ticking that would almost always follow was a pretty good sign of the problem. If I immediately took off driving, the pressure would stay up, but I had to keep the rpm's up. Once the vehicle warmed up everything functioned normally until the engine got cool again.
I bought an oil pump with the intention of changing it out but a friend told me to just change out the oil sump O-ring instead as usually that is the issue with no oil pressure in a 5.3.
On a 2x4 Tahoe it is very straight forward to drop the oil pan to access the sump and access the O ring. You have to remove the cross brace under the oil pan which is 4 bolts. You also need to remove the two oil pan/bell housing cover bolts (they hold a small plastic shield in place that keeps road grime out the bell housing. You also need to remove two bolts that hold the wiring harness in place. A simple electrical connector on the low oil sensor then you can drop the pan by removing all of the pan bolts.
Once the pan is down there are two nuts that hold the oil sump to the main bearing caps, as well as the small bolt that actually bolts the sump tube to the bottom of the oil pump. I removed the O ring and it was flattened out like a wedding ring, but not cracked or deteriorated. It was very loose when pulling out the tube as well. I put the new O ring on, which was $2 and shaped more like a fat doughnut. It was harder to press the oil sump tube back into place but it was fairly easy.
Scotch bright pad was used to clean the grime from the block where the oil pan gasket seats. I had a bad oil leak forever and the pan gasket was the culprit as it had long since flattened out as well. Once the oil pan was cleaned up and both surfaces cleaned for a new gasket I had the truck back together and running in less than 3 hours.
High oil pressure once again. With 526k miles this is the most extensive "tearing" into the drive train I have had to do, other than a 2-3 shift solenoid going back in the transmission a while back.
Hopefully this thread will help anyone with similar oil pressure issues who thinks they need a new engine, when in reality you can fix it for $60 in parts and an oil change.
Thanks for this. I have an 06 Yukon Denali and the pressure rarely gets to 40. I understand this fix is more complicated with the 6.2 engine and AWD. Mine has 183,000 miles and still runs well, but I know I need to do this.
Summajet
That is awesome on the mileage. How often, mileage do you change oil and filter? What brand oil?
InterceptorF
COlorado Springs CO 80908
OK so I did the o-ring on mine at about 200 K miles and now just today, about a year now, it started having the low oil pressure again (296756 miles). This weekend I pulled the odd bank head and replaced the lifters/ push rods/ head gasket/ head bolts due to a bad tick which fixed the tick but now the oil pressure is at ~18 psi. I guess its time for a new oil pump for me. but 500K wow!
Bofiggy
215K, low pressure issue zero at startup..After 3 seconds starts to climb to 25..idle .....after sending unit and gauge testing.. Im debating to DYI or shop.. was quoted 1100~1500. If they even wanted to do it. yup its time for the oring. no leaks but shop doesnt want to touch it unless the oil pump is changed out. (warrantee).
Sam Harris
$1100-1500 to do the o-ring…!?? What are we talking about having done?
justinakay79
