Geotrash
Dave
Richmond, VA
I did it on mine back in 2019 after dropping the pan and doing a fluid/filter change. I change out that filter once a year.View attachment 389431
Right, I forgot that until I revisited skpyle's thread. I like your filter choice better too. Looks like you plumbed yours in before the radiator's fluid cooler, yes?
Just Fishing
Can't fix stupid
Utah
I copied that config too, it's working quite well. :patriot:
St. Louis
I'm curious how messy or clean it would be to change out the fluid by having that filter removed and a bucket underneath and running the engine for a bit then adding fluid through the trans dipstick tube.
Usually I remove the upper radiator trans line and insert a barb hose adapter into the jiffy tite fitting with a hose running to a bucket.
Thinking maybe saving a step and being able to change the fluid while the remote filter is being changed?
Just Fishing
Can't fix stupid
Utah
I found it pretty much drips straight down.
I just used a 5-gallon bucket and propped it pretty close to the rim to prevent splashing.
My lines might be different since I have 1/2in, so it might have more spray with 3/8in?
So tread carefully, maybe a helper to quickly shut it off while you watch
I was also thinking about taking an old filter and cutting off the bottom, then I could use that as a shield.
probably next time I mess with it, I'll do that.
Second question: the transmission guy says lots of tuners jack the line pressures up and kill the pumps early in the 6L80. He said he'd look at the BB tune to see what they did. But he thinks that might be why it died at 140k (tuned since 99k). I've never heard of a BB tune killing a trans. Do you think there's any validity to this? I wouldn't be so quick to blame BB. If anything it's an indirect cause, as my right foot would have had a lot to do with it.
I really doubt it. Jacking up the line pressure is a very rookie move. I can't see BB doing this. A good tune should actually extend the life of the trans since it would reduce the shift confusion, slip, unnecessary shifts and general slop the factory has programmed in to make it soft and comfy.
Just Fishing
Can't fix stupid
Utah
back in the day they would boost line pressure with a part, this was pretty common on the earlier units.
I haven't heard of a pump dying due to line pressure being boosted, but who knows.
These days you can do it via a tune, and what I did was to just boost the pressure by a few percent in the clutch pressure settings.
Pretty much I didn't like how 2-3 shifted, so I would boost that until I was happy.
I also played around lightly with the oncoming pressures to help speed up apply and remove the delay and a slight slip that was present.
Do i know what I'm doing?
nope!!
With my fresh transmission with good clutch pack clearances, I didn't need much to make me happy.
I'm pretty much on a stock tune at this point, I think I have 1-4% pressure boost in some gears.
but mostly I have that since the tune was for a 5.3, and I'm no longer running a 5.3.
Geotrash
Dave
Richmond, VA
That's how skpyle did it in his build thread.
Geoffsfas10
St. Louis
Well this is weird...today it got cold and rained. Drove tahoe to work, everything was fine.
Went to leave work, acted like dead battery, one crank then gave up. Pulled key, tried again, it tried to start but the timing of the starter was real weird. Then it turned real quick and started up. Was fine once running. Drove it home and parked it, started right back up.
Went to go on an errand a couple hours later, no crank start, pull key, multi-meter on battery..12.2V...tried again and started right up.
Went to Autozone, did battery check, 96& charge and cranking amps were fine. Started fine there, went to store, started fine there.
Texting the shop who did all the work, they think I have a weird ground somewhere from everything being apart, and possibly the rain was effecting it. It was after hours, so we're going to work out troubleshooting it there tomorrow. Will be interesting to see if it starts no issue in the morning once its dried up.
Geotrash
Dave
Richmond, VA
St. Louis
Both my 2011 and 2012 6.2l had AFM and also had sticker on MC Reservoir.
The engine in your pics doesn't, so like said above, it's either been replaced with one that doesn't or someone did an AFM delete on it.
The 8th digit of the vehicles VIN will give you the engine code the vehicle left the factory with
tungsten
Thanks,L9H vin is "2" Summit website says non AFM.Haven't looked anywhere else though.
Geotrash
Dave
Richmond, VA
Sticker on the brake rez says AFM ? Twice now Ive seen this. Both engines said to be stock L9H.Weird.
Sorry, I should have been more clear. I meant that AFM was being built into the 6.2 beginning in 2009 for the 2010 model year. AFM came with the L94 version of the 6.2. I think the AFM sticker is unrelated.
pwtr02ss
Tennessee
I know we're talking about 6l but I still bump the line pressure on the 4l60s if I do any trans tuning. Not across the board but above 50%, incrementally.
Phlipnstik
