tungsten
- Joined
- Sep 22, 2022
- Posts
- 339
- Reaction score
- 613
Checked the block heater,can hear the hissing sound through the grill.Suppose to warm up tomorrow so will try starting it then.
Battery sales have quadrupled in the last week.Cold is supposed to go south? Heads up.Checked the block heater,can hear the hissing sound through the grill.Suppose to warm up tomorrow so will try starting it then.
Awesome. So no CEL or anything. Now I'm wondering how I figured out that mine was bad. I must have tried to use the cruise and then started searching when it didn't work. Glad you're fixed upReplaced my brake light switch and now have cruise control. Just in time for a trip to Indiana next week![]()
Yep, no CEL or anything with the issue. Just glad it’s resolved now and can use itAwesome. So no CEL or anything. Now I'm wondering how I figured out that mine was bad. I must have tried to use the cruise and then started searching when it didn't work. Glad you're fixed up
I had that in thecopcar when I got it. I ran a strip of coax seal over the top side of that grommet to create a dam. I haven’t seen any water since, and it’s totally noninvasive.We had horrible rain and wind for the past 24hrs - went out to put some stuff in the back and noticed a bunch of water in the hatch area...I got a freakin water leak that soaked the headliner. Putting my money on the grommet going from the top of the hatch into the body - need a relatively warmer/non-rainy day to explore where the water is coming from.
coax seal...????I had that in thecopcar when I got it. I ran a strip of coax seal over the top side of that grommet to create a dam. I haven’t seen any water since, and it’s totally noninvasive.
Something like this. You can readily peel it off later with no issues.coax seal...????
coax seal...????
What's it like to use cruze? nobody cruzes at 100 so i never get to use mineReplaced my brake light switch and now have cruise control. Just in time for a trip to Indiana next week![]()
Will it even engage when you go that slow?What's it like to use cruze? nobody cruzes at 100 so i never get to use mine![]()
good question I'll have to try it sometimeWill it even engage when you go that slow?
Yukon started fine this morning. But something looked funny. Wth. Both front tires flat? I thought a man someone’s slashed my tires. Filled them up and no problem. Can’t say I’ve ever had tires go flat from extreme cold but then we’ve never had it this cold here. Weird. View attachment 388048
Thank you and Merry Christmas.I figured something was up to have both flat.Have your valve stems checked. When it gets extra cold the valve can constrict enough to leak. I deal with it every year.
Yep mine was fkd too. I had to work and drive home in the rain just as the front hit us and was snowing when I got home. I tried wiping the door jambs with a towel to help avoid it but no dice.Mine had a water stain in the rear area when I got it. nice.
But yeah, the rain and wind were pretty insane here yesterday. We lost power for most of the day, but had a generator to keep essentials running. Ended up bugging out to the bar, and snacking while the crews fixed the bisected power lines. A big tree sliced through power, cable, and telephone on its way down.... never seen the cables slashed like that before. Usually it just rips the strand/support attachments off the poles.
All four doors on my Yukon were frozen shut, with no way to get in. I had to open the trunk and crawl over the back seats to retreive the kid's presents stashed in there so we could finish all our wrapping.
