Persistent P0420 and P0430
MrBishop
You can run an oiled filter on an LS with stock tuning tables just fine. There’s plenty here who do that. There’s also plenty here who remove the entire resonance chamber/ intake tube and install a cheap CAI with an even cheaper oiled filter with a stock tune with zero issues. There’s nothing needed to change in the tables to accommodate either one.
Depends. Look at your fuel trims before and after. My 3 engineering degrees and 22 years at GM tuning those tables and doing air flow test on filters disagree with you. I did MOPAR's too by the way. It works on theirs because they haven't figured out how to use a MAF sensor yet and still use speed density.
Do you think the air under hood is hotter or colder than the air in front of the vehicle?
This what the first go round for the 55 Chevy looked like. Car would not start with this set up until I modified the air tables, but it would have been a one off cal for this filter.
The next version, with modified air tables!
What else is different?
MrBishop
I would put a paper AC air filter in the car....
If it flows more or less than the one it came with, the table, and your fuel trims will be off even with paper. With oiled, when you clean and over oil it, you get oil on the MAF and throw it way out.
When you use one of GM's (or anyone's that requires you mount the MAF) 'cold' air kits, where should you mount the MAF?
I stand by what I said. If you want to puff your chest and argue I’m not interested. Clean looking engine bay btw but I’ve seen better. :flipthebird:
BG1988
Hello All,
I’ve been searching forever it feels with no luck. I bought a used 07 Tahoe with a flex fuel 5.3. 165k miles. Decent shape but as I look into it more, maintenance was sub par. It had P0430 and a bunch of EVAP codes when I got it. Replaced the cats since it was rattling. 4 new GM O2 sensors. Cleaned the throttle body, new MAP and MAF sensors, new thermostat (was sticking), fluids etc. Runs fine until P0420 and P0430 codes pop then it runs like crap. Clear the codes and back running fine. When the codes pop it’s the same type of driving; slow speed coming to a stop in a parking lot. Feels like the converter is staying locked up and wants to die. Transmission doesn’t seem to be an issue; I think. Freeze data shows negative long term fuel trims between -6 and -10 usually at between 515 and 530 RPM at 0 MPH. Tried the spacer fix and no difference. Plugs have shown no evidence of coolant or other issues that I can see. Decided to pull the injectors and clean them. A couple of them were pretty crappy but in the end all had good spray patterns. When watching live data the long term fuel trims at cruise speeds are in the high negatives. Ranging from -12 to -18 on both sides. Post cat O2 readings are in the .09 to .1 range, which show lean (correct?). You can now feel a really significant surge. Acceleration is just fine though. Checked fuel pressure at idle and it’s 55. I read one post that leads me to look closer at the fuel pump assembly but not looking to throw more parts at it if I don’t have to. Any other ideas for things to check? Thanks.
is any other codes present?
i have gotten both codes before but something else was causing it.. the cats are ok and passed smog NO CEL for them in the last 12k miles
Negative fuel trims suggest a restriction in the intake.. clogged air filter? debris in the intake tube(before the filter?) bad/ dirty MAF???
0.9-1 means it's running rich , negative deducting fuel , possibly leaking injectors
MrBishop
It was purposely built the way it was for a reason you wouldn't understand. Hard to hear when your head is in the sand. Instead of spending millions of dollars doing research and testing, I'll just call you, ROFLMAO.:2cents:
OldEngineer
Well didn’t don’t any leaks in the intake system. Hooked up a smoke machine and the only place any smoke ever trickled out was the air filter. Nothing from the intake or the piping. Drove around and fuel trims were between -18 and -21. I reset the trims and it goes right back. Not seeing anything on live data to justify it pulling so much fuel out. MAF seems to be correct and adjust for throttle position. The one thing I couldn’t figure out was the PSI reading on the MAP. Is it supposed to be positive? Is it in relation to the barometric pressure value? I need to research this. At idle it’s around 5.5 psi and goes up with speed. But when I get on it the value still goes up. I would expect it to be high at cruise and a little lower at idle. But I also would expect it to drop when I get on it. No? Frustrating. Don’t want to burn a hole in a piston. Where to next? Thanks all.
Your last message was in Feb, 2022.
Any success?
Still getting the same error codes?
5StarCustmSolutns
Almost Heaven, WV
55 psi at idle seems pretty high
Mine run same range as OP's?
Have you replaced the intake gaskets?
Do you have any exhaust leaks around the manifolds or at the connection between the manifolds and y-pipe?
I do have a broken bolt head on #8 manifold. No visible sign of leak on head. Could this be contributing to a rich run condition? I've propane tested the intake area three times and found nothing, smoke tested the inward side twice and found an either. Just about have myself convinced I have an intake leak that only manifests when the engine lifts/torques under a cell load??
Explain how it takes an electrical signal and converts to an airflow value.
More air flow lowers temp of MAF sensor wires and vice versa?
Never would I try and tell someone w/your amount of experience on any subject what was right and wrong about that subject, but I've been having these same rich running neg LTFT for 24 months now. Purchased the truck 8 yrs and 2 days ago. Installed and oiled K&N 7yrs 11mos ago. In fall of '20 I removed entire stock air intake system and built the DIY in the attached pics thinking it might fix the prob....which it did not. Exact same FT's, low mpg and ill sounding cold weather starts. Just my personal experience
see above post/photos
***There is one thing (Fuel Alcohol Percentage) I didn't see elaborated on in this thread that I believe to be the cause of my issue. When scrutineering through my live data trying to fig this out, I noticed that my FA% was/is always 60% or higher. 61%, 67%, 73%, 81%, even when putting 4-5 gal of E-0. Last summer I ran 3 straight tanks of E-0 gasoline and reset my FT's and my FA% at first fill-up and EVERYTHING went back to normal for the duration of that gas. Within 2min of starting truck after switching back to 87 octane everything went right back to rich??
Sorry for long-winded attempt to revive a thread that looks to have had potential to help me with something I haven't been able to figure out.
Thanks you all in advance
B-train
Is this a flex fuel truck? If so, I wonder if the fuel sensor has failed. If it thinks there is that much alcohol in there, it's going to dump in extra fuel trying to keep 14.7:1 ratio. I know when I ran a tank of e-85 in my 2008 denali (non-flex) it ran like a champ but I got lean bank codes after a number of miles due to it not being able to satisfy the fuel rate needed. No lasting damage as far as I can tell.
As a test, I wonder how it would behave with a tank of e85, or a higher blend to get to the 60% mark it thinks its seeing. Just a thought
If this is about the 2011 truck in your signature, it has NO physical flex fuel sensor unless someone added one. It's all done by the PCM/ECM calculations.
If you know for certain that the actual alcohol percentage is low, reset the long term fuel trims and reset the alcohol percentage.
5StarCustmSolutns
Almost Heaven, WV
Yes it is flexfuel, w/154,xxxmi - 123,*** by me. Always hesitant to say 100%, but I'm fairly confident they abandoned the physical fuel alcohol sensor beginning w/the 2006.5 models. GM went to the V-FFS multi sensor algorithm. I have, I guess you would say, "settled on" the exact thing you described as happening. Thinks it's really 67% FA% in the tank so it pours the fuel to it trying to reach 14.7.
However, of all the testing and experimenting I have done, I have not put one drop of e85 into it. As I read your words I started smh and thinking "why have I not tried that??", just to see what happens? I think the answer to that(speaking about myself only) it would have to be tunnel vision and/or ego. TV from only being able to put so much time into it per garage session, it's 2am before I could even sit down and answer these. Ego being something I learned was holding me back as a designer/builder 5-6yrs ago(slowly won that battle). Part of the ongoing growth process. Plus I just read about ego being referenced on an HP Tuners forum yesterday. Thanks for the suggestion....going to try e85 next and will report results
Yes sir that's how I understand it to be since 2006.5. An algorithm that formulates FA% from the readings of multiple sensors. [In hindsight it would've been for others trying to help me had I elaborated more on the hypothesis I'm working from now and how I got here. I just started quoting the better sounding repliers and made this conglomerate message. Sorry....I was already behind my target departure time and got a little too excited when I read the level of the follow-up questions and the advice on this subject in two other threads.]
Not sure of all the sensors used but: MAF, MAP, IAT, Evap Purge(?), Fuel Press, O2's, Knock(?), and possibly others. Sorry eyes getting heavy.
Read about it first here: https://www.chevelles.com/threads/gm-tech-alcohol-fuel-sensor-question.849586/ third post down.
This may be a sign of how little info is out there on this: I've watched that exact video. He has a few other on this same subject. He also tests the gas in a couple. I have reset my FT's and my FA% at least 3 times the first time while putting 3,5,8 random gallons of E0 into the mix. And again when I decided to run 3 straight full tanks of E0. Only then did all FT's and MPG restore to normal OE spec. But within minutes of filling up with 87 again, everything was back out of whach.....I watched the FA% go from 3-6-17-28-49-73 in the first few miles
There's also been a TSB on subject saying the solution was to take it into dealer for reflash, but I've read several owners say it didn't help them only drained their wallet$?
I'm excited to see if e-85 might straighten it out? It makes no sense but neither does what's happening.
THanks for your suggestions
5StarCustmSolutns
Almost Heaven, WV
I also met the parts Depot Mngr for one our local Chev dealers at a party last fall. He became a little intrigued by this and asked a few of his service guys and either they refused to give him the answer w/o my bringing it in -or- they were stumped also??
I feel like if I could pin down exactly what sensors the V-FFS uses I could go through them one at a time and get to bottom of it?
A couple of suggestions, then. If this is happening all the time then it might be worth having the computer calibrations checked for updates and having a search done for any TSBs. Flashing the ECM shouldn't be all that pricey, either at a dealer or an independent shop that's familiar with GM programming.
Any time enough fuel is added (I think 3 gallons?) the fuel/alcohol composition is recalculated. This can take a bit of time and it's recommended that the truck be driven for several miles (7? 10?) without shutting down the engine. Pretty sure @swathdiver has posted up the specs at one time or another; maybe he can clarify. Shutting off the engine before the calc is done can cause issues with the percentage.
5StarCustmSolutns
Almost Heaven, WV
Thanks you for the suggestions. I broke protocol yest morn and quoted the several members that I felt had the best replies on the three threads I read, and did it all in one long post. 1. I know better than to make small novel posts tagging multiple people because they're confusing and people don't have time to sift through them. 2. I know better than to ask for answers after only reading three posts. Both are just bad strategies on forums.
Somewhere in that quagmire of a post I mentioned finding that same TSB and also finding several people that followed it's direction and then vented their frustration over paying to have their pcm updated and still having the incorrect FA% issue.
Last night I ended up reading on here until way late, which is what I should've done before posting anything. My excitement for answers got the best of me yesterday morning. There's a lot of info on this subject on this forum. It may need to be gleaned from a discussion on EVAP purge canisters etc. but it's here. I need to make/take the time and find it.
It was two years ago this month when this started and it was two years ago last month when my Torque Converter shudder started(which I haven't even looked up on here since joining). These two "conditions" have forced me to learn more than I ever thought I would need to know about computer controlled modern automobile systems....and have motivated me to buy an HP Tuners interface and a dedicated laptop for it and for the Power Commander software that's on my Grizzly. The Autel I have has been great to learn with but doesn't have many bi-directional features, which are required to diagnose and fix a lot of this stuff. This concept wasn't even on my radar two years ago when this started lol.... I've enjoyed the education process though.
I'll post results of how my LC9 reacts to the e85 tank.....and when I finally determine the responsible party for this FA% mess I will share it's name with all lol.
Baffles me why so few follow up and share their results after asking for and receiving guidance! First recognized this a few years ago trying to save $4900 bones by changing the front driveshaft on my wife's Mercedes....don't get it
It is perfectly normal for the percentages to move around along with the LTFTs after refueling. If you find that your truck is registering too much of an alcohol content when it should be 10% or less my issue was old oxygen sensors. They still functioned fine in their primary job, moving about like they should but started inaccurately calculating the alcohol percentage until they were replace with new OE sensors.
5StarCustmSolutns
Almost Heaven, WV
Thanks for reply.. Changed O2 sensors in June '21 and everything was back to normal for about 2 weeks, I even posted about prob being solved on Av forum....and then it went right back to rich condition and large negative numbers on LTFT.. However I did buy cheap sensors!?!?
One thing I have yet to do is pull the intake and check gaskets and manifold bolts....I've read a couple places about the gaskets causing similar symptoms and about the manifold bolts underneath the intake being loose.... You would think my propane leak test would've found a prob there though?
Yes, your propane leak test would expose a leaky intake gasket. I kept tightening mine up for years and finally just replaced them. The high trims at idle lessened for a time but started creeping back up again. In my case, I wonder if the plastic intake is simply warped from age.
Aftermarket oxygen sensors do not play nice with the computer system and cause problems almost always.
5StarCustmSolutns
Almost Heaven, WV
It very well could be in both of our cases? or has a hairline crack that may only become a "vacuum leak" under load? Somewhere in my multi-quote quagmire of a post I wrote that I felt like mine was possibly only leaking under load, when the engine was twisting and torquing around in sequence with my foot??
Side note, I've spent too much time in the last 3mos looking for a good used diesel to pull a compact track loader with(commonly called a Bobcat here lol, no matter the logo, just a Bobcat). During the search I started noticing a trend in the straight on from behind pics. On hundreds and hundreds of trucks the drivers side rear bed corner is a little lower than the passenger. Brought this up at a local engine builders shop one Fri eve in Nov with a few savvy customers and the full staff present and nobody had an immediate answer why?? I'd been thinking about it since prob mid-Sept and suggested it may be that the frames are slightly torqued from years of the motor slamming down on the drive side of the cross member? After a lengthy discussion about gas tank and driver weight, road camber, repeated closing of driver door, etc.. we settled on the engine torque theory.
So I wouldn't rule out a warped intake or some form of crack/gap separating under load??
It's certainly possible, there are lots of connections on the intake too that can leak or develop cracks. I almost replaced mine but held onto the $200 or so. If the trims run wild again I'll just replace it with a new one.
Buford bubba
