2004 Tahoe operating temp issue.
Engine temps while driving look completely normal. What is the temp at idle?
Idle values from post #2:
Scottydoggs
NJ
you might want to grab and hold the heater hoses, engine up to temp. see if they are hot. both should be warm to hot. if one is hot and the other cold the heater core might be air bound, or clogged up.
ive got warm air in my hoe as soon as the needle lifts off the lowest temp.
nonickatall
Germany
I do not think that you have a technical problem. I know a lot of cars and they all need different time to get hot. The big V8 engines need longer than modern diesel engines, which have mostly additional heaters to reach fast the operation temperature because of emmision purposes.
See it like this. Engine heat is a waste of propulsing Energie. So ist takes a while until there ist enough energy wasted, to reach operating temperature.
Mine as well needs 5 Kilometers or more to reach temperature.
If you want that you car reach temperature faster, for example if you life in a cold area, use an auxiliary heating system.
93M6Formula
So the other day I put a clamp on the hose to the coolant tank so that it barely flowed. It warmed up much faster for sure but then ran a tad warm, but still around 203° according to my scanner. Opened it back up and back to long warm up. And yes the lower hose is cool. Heater hoses are fine, it makes heat. Thinking it's probably going to be just another junk stat, idk why it's so hard to get a good one.
rockola1971
Indiana (formerly IL)
203 is not "a tad warm". Its actually closer to normal.
Start your engine up cold and watch and the temp gauge to see what the highest it achieves until you all of sudden see it start to drop (which means your thermostat just opened up). WOuldnt hurt to ignor your temp gauge and hook up a scanner and get temp data from there while watching temp gauge to see the drop. Your scanner data temp may not respond fast enough for you to get accurate numbers to work with as far as the opening point of the thermostat.
Larryjb
We had a vehicle that wouldn't warm up, or barely warm up after driving. Some one had cut out the core of the thermostat. It's time to look at the thermostat, just get a new one. Unfortunately, it's a pain to change.
93M6Formula
I agree, what I mean I guess is that it was warmer than it usually is. The gauge was showing roughly "225" instead of "210".
93M6Formula
This is with that line basically clamped shut. This was showing about 203-207 on my scanner.
Charlie207
LFOD, New Hampshire
@Charlie207 posted a few pics in this thread. The restrictor is a small orifice built into the radiator fitting for the small return hose going to the surge tank.
If anyone wants spent .45ACP brass for this mod, let me know. I'm happy to throw one or two in an envelope and mail them to you.
OD post-fireforming looks to be 0.478" which fit snuggly, but easily, in my GMT900 overflow hose.
I'll let you drill it out to your preference.
93M6Formula
I think I will probably just get a new thermostat again and test it this time before install. Kind of want to get a new GM pump too just to be sure nothing is wrong with it. All I know is it shouldn't take a 5.3 gasser longer to warm up than my diesels, that's why I bought a gasser again for winter lol.
rockola1971
Id rather you throw the magazine in a mailer and send it! I have all the .45 acp brass that I need. :p
rockola1971
Not alot to go wrong with a water pump. It can leak past its mechanical seal, impeller could come off its shaft (overheating would happen then) or the impeller could corrode away (overheating would be the symptom for that too).
93M6Formula
My worry I guess is that it's some super cheap aftermarket replacement that has some flaws, it's definetely not original. Wondering if it's an issue with the thermostat surface. Just spitballing at this point.
rockola1971
Another quick and dirty check is to squeeze upper radiator hose between your thumb and index finger on a cold enngine and see if you feel a surge of coolant trying to push your fingers apart. This should not be happening on a cold engine. If it is then it means the thermostat is stuck open (Before the engine is even warm).
nonickatall
Germany
How long did it take, at 32° Fahrenheit to get the temperatur in the middle of the gauge, when driving normal?
I would like to know to compare. My Escalate 6Liter needs minimum 3-4 Miles or more. What is normal on this engines?
Mckennahc
