Tahoe Clunk
Multnomah Falls
Military
Based off what you say did you get any of the normal bad bearing noise that happens when driving and rock steering wheel from 10 to 2.
JPVortex
JPVortex
Connecticut
Wiggling at 9 and 3 could be steering linkage as well. If it wiggles the same at 12 and 6, then it's most likely a bearing
I pryed on everything, didnt feel any play in any ball joints, tie rods, idler or pitman arms. Only the click from the bearing or cv axle.
JPVortex
JPVortex
Connecticut
Your sway bar links appear to need replacement soon; I'd recommend replacing those and the sway bar bushings on the frame before you tear into anything else.
Yeah they definitely do, but I dont think those are the cause of the clunk. I've had multiple vehicles that needed the links and they sounded different and the clunk usually only happened over bumps, whereas the Tahoe happens anytime
JPVortex
JPVortex
Connecticut
I guess you could say it sounds a little bit like gravel or something rocking around in the bearing like someone else mentioned, but I dont notice it in any one specific condition. it seems to just happen all the time. I may try to get a video of the noise drivingm
JPVortex
JPVortex
Connecticut
Another thing is driving it in the rain today, I didnt really hear it at all, its more when its dry out, interesting.
Multnomah Falls
Military
You did not hear it over the noise from driving on a wet road. Sounds like a bearing/hub problem.
JPVortex
JPVortex
Connecticut
Alright y'all here's an update, back to the drawing board! I wiggled the tire on the other side and heard a slight similar clicking sound.
DefiantOne
