Didn’t think that process to program keys or FOB’s worked on 2013 and newer vehicles.key is chipped so it would need to me programmed to truck, that's easy: start vehicle with original key, remove key insert new key within 10 seconds and start and done. fob can be done in a simple way as well. you can go factory key or aftermarket.
Fob you can go factory or aftermarket. there's a vender that sells upgraded fobs from 14+ to work on the nnbs.
Can you share how you programmed the fob? I also have 2013 PPV. TIAi bought keys on ebay, had the locksmith cut them and programed them myself. I got a 2013 ppv as well
If you have a tech2 its special function under bcm i believe you should have clear and add as an option, could be under the rcdlr but i feel like that might have been a chrysler programming option but same thing once you start the procedure you just hold lock and unlock. Random thought alot ‘06+ of trucks that had power locks and no fobs were also capable of adding keyless entry for without calling in the upgrade did it for alot of my friends when i worked at the dealership just by programming the keyfobs.Yeah, I would be interested...I have a spare key and fob but only the key works...I think! I do have a tech2 at my disposal also.
I added and deleted fobs from my '03 using a process with the key and hoping on 1 foot/rubbing my belly! Super easy - I saw the add a Fob in the Tech2 but was hesitant because I didn't want to delete my known working one from the truck but sound like that is the process. Anyone confirm????
