Fuse was missing. I replaced it but still no dice. I hear the relay kicking in and I have power through the fuse. Guess I'm gonna have to check power in the door harness at the mirror switch and compare the plug on the new mirror to the old one I saved. And check wire colors etc.
You're turning the defroster grid on, right?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yeah bottom button to the right of the power button on the HVAC panel.
Old mirror plug on top, new one on the bottom. Same number of wires in same positions. Colors are different, but I believe the functions are the same regardless. I test plugged in the old mirror and that won't heat up either. I opened that mirror up on the bench and did some tracing with a ohm meter. The black wires on BOTH plugs are definitely for the heated glass. I am afraid to go prodding around the door lock module with test meter probes.
89Suburban
SE PA
yeah I dunno wtf is going on here fuse is good, relay good, rear defrost button is lighting up. Still no power reaching the heated mirrors. I am wondering if the door lock control I replaced isn't programmed for it maybe?
StrkAliteN
I hope every one had a great Thanksgiving ! I have been away awhile.
Have a shock replacement question: 2007 GMC Yukon SLE 5.3 Flex fuel
I need to replace the original ( 77K miles ) rear shocks. The OEM ones are pictured as are the heavy duty ones.
I never tow anything, but will be towing a 20 foot cargo trailer next summer from Seattle to Ohio and am thinking maybe I want heavy duty shocks vs OEM standard
Everyone's thoughts ? thank you in advance
Geotrash
Dave
Richmond, VA
Everyone's thoughts ? thank you in advanceView attachment 386163View attachment 386163
Welcome back!
In my opinion heavy duty shocks won’t offer significant benefit over the factory part for towing. The problem won’t be damping - it will be sag. For that you’ll need either adjustable air shocks or supplemental air bags.
Sparksalot
Bastrop County, Texas
Ah, I was wondering if there some kind of display thing happening with the camera and Mirror
it's just a hard wire adapter to supply power from the mirror harness instead of having to have cables hanging down to the cigarette port. I use a similar one for my radar detector and another one for my dash cam
89Suburban
SE PA
89Suburban
SE PA
check for continuity on the mirror wires
Already did. They check out. The door switch is not sending power to those wires. So I don't know if it is a programming thing with that or the problem is between there and the defog switch. Need to look up some wiring diagrams and chase it down.
Hodmjstone
