Anyone had the transmission TSB done?
KMeloney
Hey all,
Not sure if I still just don't like my tranny, or if there's a problem with it.
I know there's a TSB out for the tranny where there is a seal that leaks, making the tranny feel like it's "hunting" for gears. I wonder if I have this issue.
Has anyone had this TSB work performed? If so, what symptoms, exactly, were you experiencing? And how long did it take the dealer to perform the work? Is everything better now?
Thanks, folks. Need to take the truck in for some loose windows, and thought I'd have them look into this as well.
/< / /2 /<
Zed 71
Pacific NW
I had a tranny TSB done to address the seals. Tranny was leaking, but no performance issues and no change afterwards (except no leak).
rogersinsel
Hey all,
/< / /2 /<
Where does it leak?
KMeloney
KMeloney
Where does it leak?
Actually, just found another:
NHTSA Item Number: 10032393
Service Bulletin #: PIP-4686
Replacement #:
Vehicle/Equipment Make: CHEVROLET
Vehicle/Eqipment Model: TAHOE
Model Year: 2009
Mfg Component Code: 103000 POWER TRAIN:AUTOMATIC TRANSMISSION
Date of Bulletin: 2009-08-01
Date Added: 2010-03-15
Summary: CHEVROLET/CADILLAC/GMC: HYBRID DRIVEABILITY OR CUSTOMER CONCERNS OF FLARE, SLIP, STALL AT A STOP, SURGE, LACK OF POWER, POOR FUEL ECONOMY, REDUCED EV RANGE/LIMITED ELECTRIC PROPULSION, DTC P061B AFTER CAMPAIGN 09102B OR DTC P061B PRIOR TO
But, to answer your question:
NHTSA Item Number: 10026149
Service Bulletin #: PIP-4395
Replacement #:
Model Year: 2009
Date of Bulletin: 2008-08-01
Date Added: 2008-10-02
Summary: GMC: FLARE AND OR HARSH 2-3 SHIFTS. THIS CONDITION MAY BE CAUSED BY LEAKING 1-2-3-4 AND 3-5-R CLUTCH FLUID SEAL RINGS (230). MODELS CADILLACS, CHEVROLETS, GMC, HUMMERS, PONTIACS. EQUIPPED WITH 6L80 (RPO MYC) OR 6L90 (RPO MYD) AUTOMATI
---------- Post added at 02:18 PM ---------- Previous post was at 02:15 PM ----------
Actually, looks like that first one is only for the Hybrids -- but, it's exactly what I'm experiencing in my non-hybrid.
daddyrim
Timmins, on
I am having this exact same issue on my '08 yukon Denali XL. Its going into the dealer on May 8th which is the earliest it can be seen. I know this is an old thread but I'd like more info if anyone has had the same issue with their 6.2L 6-speed models.
skippy737
NW IN
Where are these leaks? I seem to have a small oil spot in the middle of my hood in the garage. 2010 with 13,600 miles. Bs!
GM Customer Service
Michigan
daddyrim,
Hi there. I would like to follow up with you once your vehicle is out of the dealer. Please keep me posted.
Thanks,
Jennifer T,
GM Customer Care Service
CKendrick
