Wheel Spacer sizing
40Rouge
Bumping this thread for the sake of having this info searchable for the next guy...
I installed 1.5 inch Bora's on a 2018 Denali with the stock 22's with no problem whatsoever. As mentioned in a number of threads, 1.5 inch will result in the stock studs protruding beyond the spacer, but there was plenty of space in the indentions behind the stock wheels to accept them. No stud trimming needed. The 1.75 inch spacers would hide the studs flush.
No tire rubbing at full lock, but I do have a 1.5 inch front level kit from Suspension Maxx.
MrAguirrechu
View attachment 385692 View attachment 385693 View attachment 385694 View attachment 385696
Reviving an old one.
Stock size tire?
Oh Kee Pah
MAINE
I've been running 1.5" spacers on my rear OE Chevy wheels for over 40k miles now. Had them on both my 20" and 18" wheels, BTW.
Yes - check the back of your wheels. There should be an indentation for where the hub studs will extend into...
40Rouge
I do want to add an update: There isn't any rubbing at full lock, but there is very slight rubbing at about 50% turn. The shape of the fender liner bumps out a little on the front side, enough to give a little rub.
Drewphil
