Sparksalot
Bastrop County, Texas
His the f do you get out of it, out the hatch?
The teardrop is actually in there at a slight angle to make ingress and egress easier when pulling it. The garage is perpendicular to the driveway. So I had a narrow gap at the driver door. But there’s no way to open the rear door for my 110# hound.
m1dn
Today i had to do something very sad with my gmt900, put the boat away for winter, now waiting for March.
The garage is extremely tight fit, the boat fits precisely wall to wall thanks to the foldable tongue haha, garage is 24ft, boat is 19’6 plus engine plus trailer
The motor side is splined, but the arms are not. The new arm did not have splines either, but they are tapered.
I bought a new front wiper arm at the dealer a few years ago and it wasn't splined, either. Parts guy said that the posts would cut the splines on the first install.
Fubar0715
Scott
Southern New Hampshire
The weather report is calling for actual winter weather, so I extended my lunch break to swap on my winter wheels/snow tires.
That's funny - did that on Wifey's car on Sunday for the same worry! BTW, is that an E39 (5-series BMW) parked next to ya? Your beater with a heater in the great north woods!
Onlyone
New Mexico
Changed the oil, front diff fluid, transfer case with Amsoil and replaced the rear shocks with some OEM spendy bastards. Wow it rides good now. I just need the fronts but they can wait a bit. I’m beat. Yes, I cut the splash shield to get to the bolts, I’m a lazy Jeep owner who’s care not about splash shields.
Charlie207
LFOD, New Hampshire
Yep, current project car. 2001 540i/6MT
Has some rust issues, but also has some Dinan goodies. Maybe Santa will build me a huge garage for Xmas.
Changed the oil, front diff fluid, transfer case with Amsoil and replaced the rear shocks with some OEM spendy bastards. Wow it rides good now. I just need the fronts but they can wait a bit. I’m beat. Yes, I cut the splash shield to get to the bolts, I’m a lazy Jeep owner who’s care not about splash shields. View attachment 385279View attachment 385280View attachment 385284
View attachment 385282View attachment 385283
not sure why you needed to cut the shields? I didn't have to cut them nor remove them.
DaveO9
Vancouver, WA
Removed the tiny screen below the oil pressure sender. In the two months I've owned it I've never gotten a low oil pressure notice or any codes, but pressure was showing below 20 at idle and not even quite 30 at speed. Definitely a challenge getting the sender out with just removing the two vacuum tubes that are nearby, but it was worth it. I didn't drive it after the mod, just started it and let it run for a few minutes, but gauge showed almost 40 afterwards. I'll drive it tomorrow to see what it shows at warm idle and at speed.
As to the value of the screen (I didn't replace it, just left it out) everything I've seen shows it was to protect the DOD stuff. Mine has DOD delete so I figured I was fine removing it.
Geotrash
Dave
Richmond, VA
I left mine out in my 2012 after the afm delete. 20k miles later and no problems.
tungsten
So units without DoD wont have the screen?
Korbin_A
