ADAPTIVE CRUISE CONTROL RECOVERY HOOKS
Mitchell0827
Hello,
I am new to this forum and have been finding a lot of useful information thanks to everyone here. I have a 2015 GMC Yukon Denali and purchased a new front lower fascia with the tow hook openings and a pair of new tow hooks. I do have Adaptive Cruise Control on this vehicle which has stopped me in my tracks as far as this install goes. I don’t want to eliminate the ACC feature as I enjoy it on the highway. Surely someone here has come up with a work around for this issue? Or should I just return the items. I cannot find any solution for this issue on Google or any other site for that matter.
Any information would be greatly appreciated.
Thank you
Bill 1960
Testing the Limits
I would consult my local dealer (assuming you have a trusted one like I do) and determine if the recovery hooks were an option compatible with ACC from the factory. If they were, there’s probably a calibration for that combination of hardware.
You may be able to find this out independently if you can locate a copy of the ordering guide for that model year. That will describe all the options and which combos are compatible or incompatible.
Mitchell0827
Mitchell0827
Thank you for your quick response Bill. I have viewed all of the parts diagrams from the dealer and what I’ve found is that “factory” I am not able to install tow hooks if the vehicle has ACC. I was hoping someone on this forum had found a work around for this slightly frustrating issue. The ACC module is bolted to the front of the Left side frame rail. Leaves me absolutely zero room for tow hooks. I have looked all over the net for either some after market bracket or part that would allow me to either relocate the ACC module, or simply work around it… no success. Hoping someone has succeeded me in accomplishing this task. If so please let me know. Thanks.
Welcome to the Forum from NH.
Pics of the truck, please.
Just curious..... Is this mod for some use case where you actually will use the tow hooks, or is this just for show, as in red tow hooks?
Mitchell0827
Mitchell0827
Hello Joseph,
The tow hooks would be for aesthetics more so than actual use. Although, from what I’ve read… the passenger side has no restrictions as far as installing the tow hook to the frame rail, only the drivers side has the ACC module blocking access/use of frame rail.
Thank you in advance for any information you can provide.
SeventhFullsizeGM
I looked into this shortly after I bought my 2019. From what I was able to determine, you had to choose either the recovery hooks or ACC. If you'd really like a recovery point up front, I don't see any reason why you couldn't cut a hole in your existing front valance and install just the passenger's side hook. It won't look symmetrical, so perhaps not the aesthetics you are looking for, but it should be a viable option. Good luck!
Ghost10
Setina sells a relocation kit
It's for the push bars on the Tahoe PPV models.
Mitchell0827
Mitchell0827
Thank you all for your responses! Ghost, I cannot seem to find the ACC relocation kit your referencing on Setinas website for a Yukon. The only ACC relocation kits I can seem to find are for Ford F-150s. Do you by chance have a link you could share?
DenaliBQ
I am interested as well as i have a setina push bar on my yukon and need to relocate the acc radar module..... i have tried to find a harness extender but have had no luck
DenaliBQ
i believe the 2015 escalade had there acc radar in the center and i think it was attached to the crash bar i wonder is we could buy that crash bar and bracket and mount ours there but would have to do more research to see if its even possible.
Ghost10
If you do a little searching you’ll find these little metal brackets that’s all you need to relocate
DenaliBQ
Those are for the parking sensors I have that already we are talking about the radar module behind the drivers tow hook for the emergency braking ….. that’s a parking sensor relocation kit for push bars
Ghost10
Oh I misred I’m sorry
I thought that sensor was in the rear view mirror ?
Mitchell0827
Mitchell0827
Thanks for your responses. There is no way that this seemingly simple mod hasn’t been performed by someone in the past. They offer ACC relocation kits for the Ford trucks and the Dodge Ram trucks. Hard to believe that nobody has manufactured a Yukon or Tahoe ACC relocation bracket….. YET here I am, after an exhausted search online and locally… there is literally no option for this Mod that is readily available for purchase. If I had more time on my hands… I would get the spec sheet pertaining to the field of vision and angles that the ACC module needs to perform properly and safely. Then would simply go to my local salvage yard and cut the pigtail and whatever length I would need from the harness. Finally, I would manufacture some brackets mimicking what Ford and Dodge relocation kits offer for behind the grill or bumper mounting. Or just buy their kit and modify to work with what I create.
Seems someone could easily replicate the other manufacturer's design with a little research, time, and elbow grease. Willing to bet that individual would make some serious cash. Am I wrong about the way I would go about this? Any other thoughts on the subject?
cardershack
I have a 2020 Tahoe LT 4wd. I just purchased the recovery hooks and front fascia piece with the holes for the tow hooks. Reading through this thread I’m realizing I may be running into the adaptive cruise control problem. I’m going to verify tomorrow by looking under the truck but I have the buttons on the steering wheel for ACC.
Has anyone figured out how to add recovery hooks with ACC? I really need the recovery hooks in hunting season and will be pretty bummed if I can’t add them. I don’t want to not use ACC because I bough the truck as a safe family vehicle but I launch boats in some off the beaten path places in hunting season and it’s common to need a pull from time to time. Hopefully someone has figured out a way around this by now. Appreciate the help in advance
Mitchell0827
Mitchell0827
@cardershack
So, I actually never ended up getting an answer that would work from anyone. I’d asked every single website that sold bracket relocation kits for Fords and Toyotas, with no success.
Out of sheer frustration I did the following-
What I did was disconnected both of my batteries (I added the PPV two battery system last year). I then took the Positive and Negative cables, zip tied them together overnight to ensure all power had left the vehicle. I knew whatever I was going to do, I didn’t want the ECM, BCM, or whatever other sensors to realize what I’d done.
The following day, I removed the bumper cover and stared at the ACC module and bracket for an hour or so, cursing the engineers at GM who came up with this ridiculous setup.
Then I started looking at the wiring harness that is somewhat running along the driver side frame rail. There are two plastic clips that hold the portion of the harness that goes to the ACC module to the frame rail. I removed those clips and unplugged the ACC module.
Then I disconnected the ground cable from the frame rail, just to the right of where the ACC module is located (it’s only one bolt).
I realized that the only logical (best chance) place to relocate this module so that the tow hooks wouldn’t interfere with its field of vision was exactly center of the crash bar, beneath it, almost flush, slightly back with about 1/4” of crash bar cliff above (to allow the crash bar to still be the furthest solid object forward).
To my amazement, there was just enough harness coming off the frame rail for it to reach the new location! I had to snake the harness up and over the frame rail, then over to the new location.
There is only the lower portion of thin plastic on the front bumper cover in that area, and it being directly centered between the two tow hooks, it was the best chance the Module would have to not encounter interference issues.
No science or engineering here, this is all me basically choosing the best logical route (that could be easily reversed if it didn’t work) to give me the best odds for success IMO.
Then I unbolted the ACC module from the frame rail, realized it would not come out even unbolted without removing the crash bar. So six bolts later, the crash bar is off and out comes the module with bracket intact.
Now, I made certain not to disturb the orientation of the module on the bracket itself, as I didn’t want any MORE possibilities of calibration issues IF the electrical system noticed it was relocated after reconnecting the batteries.
I then slid the module back into the frame rail (after thinking this may actually be feasible after all) and bolted it back up to take measurements.
Remember, not a single soul had given me any direction and I was frustrated but determined to see it through. I just needed to make certain that I gave it every possible chance to work.
So, I took my measurements.
The ACC module in the OEM position sits almost exactly im the same position and orientation as it would being mounted under the crash bar. I then made certain that the side to side orientation was as close to the oem position as possible.
I then removed the module again after making my measurement marks with a marker. I had a bunch of angle iron in my garage and needed to design a “temporary” bracket prior to having one welded up (to make sure the thing worked).
So I mounted the ACC module with the bracket (very tail heavy but it was temporary until I test drove it).
Cut up some of the angle iron, Drilled four holes into the back of the crash bar, and mounted the darn thing.
I then reconnected the wiring harness to the module, and ran the ground wire back up and over the frame rail to the factory position. You will have to deal with GMs horrible black tape to get enough length for the ground wire to run back to the original frame rail position alone without the harness
(Or you could just make your own ground, I just didn’t want to chance ANYTHING!). Lol.
Well to my amazement, after reconnecting the batteries, and starting the vehicle…
ZERO WARNING LIGHTS on the dash!!
But that meant nothing yet, because I knew I had to take it on some backroads at night and get up to speed to mess with the adaptive cruise control before I claimed this as anything close to a success.
I took it out late around 1am, had my friend drive in front of me in my other vehicle. While on the phone with him, I played with all the distance setting while in cruise controls and had him SLOWLY reduce speed and then speed up again, over and over, until I was satisfied that it was working properly. My foot was ALWAYS hovering over the brake just in case it failed. Yet it did exactly what it was supposed to without issue.
It’s been working perfectly ever since. Many highway trips without issue as well.
THIS IS NOT A RECOMMENDATION BY ME!
I AM SIMPLY TELLING YOU WHAT I DID AND HOW IT WORKED FOR ME…
At the end of the day, for all I know it could’ve been dumb luck with the measurements and I’m a fraction of a millimeter away from it never coming to fruition in the first place. Lol.
Hope this helps you a little bit.
I had to become Tom Hanks in Castaway due to lack of viable solutions from anyone! Considered painting my wife’s face red with my daughters finger paint while she slept… just to yell “WILSON” ! Lol
Seriously though, it’s the simplest problems, that don’t seem like they should be problems, that get under my skin and drive me
(sometimes to the brink of insanity) to find solutions.
Well, Thats all I’ve got for you.
I’ve attached a couple pictures of the
Big piece of metal on wheels.
Goodnight.
cardershack
@cardershack
Goodnight.
I really appreciate the detailed write up on this. I was planning on having my dealership do this for me also. They didn't confirm for sure if it would work or not because I didn't talk to a technician rather I spoke to someone in the collision center office about scheduling it and getting a rough price on the labor. I've researched this until I was blue in the face and finally went to buy parts and talk to them about doing it for me and it was not until then that I continued reading threads adn realized I'll have this problem.
I really want the front recovery hooks not for looks but because I need them in hunting season. I duck hunt and put my boat in anywhere I can squeeze my trailer so there are times I need a pull to get out. I'm not interested in having 1 tow hook although I would entertain it if it wasn't that noticeable since I already have the parts. I'm going to think long and ******* doing this myself and trying to do what you do. It would be very helpful if you could send some pictures of what it looks like in the new position. Thanks for all the help. I guess its on me at this point and not the dealership to do the labor. I'm fine to do this myself but I have a 3 month old and time is valuable these days!
cardershack
@cardershack
Goodnight.
Do you have pictures of where the ACC mounts up? I just looked under my Tahoe and don't see it and not sure I see where the tow hooks would get in the way of anything. I have the button on my steering wheel but I can’t tell if I have this feature or not. Can anyone help me figure out if I have ACC?
a1parrothead
