donjetman
Added 16 oz of R134a. Compressor was short cycling and air wasn't as cold.
Hopefully the leak is sloooooooooow. The only area that was wet/greasy was at the Hi pressure service fitting.
We've ownered it for 4 yrs and this is the first time I've had to do this to it.
DJones
Largo, FL
Installed a set of warm white LED dome lights.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Anybody know the best way to manually adjust a seat forward or back. Damn motors went out.
Check this post out:
tag: seat adjust thread
tungsten
What is the issue with the rear wiper?
Noticed mine fell off and doesn't seem to want to clip back on.
Havent looked at a new one.Assuming something fell off?
RooTBeeRthe1st
I'm not sure, this is only the 2nd one I've lost in 4 years. But I assume replacing the arm will help hold the blade better. ‍♂️
Genuine gm arm was about $50
m1dn
Or you could do what I did and take it to a locally-owned quick-lube shop and have them change the front diff fluid for you. The mechanic came into the waiting room when he was done with a big smile, holding the old plug and the tool they use to get them off with when they're rounded. He said they always keep spares in stock because it's such a common issue for them. $75 and 20 minutes and I was out the door. I even had time to stop for a donut and coffee on the way home. :)
Just did that, local shop had it out in few minutes, thanks!
Drain plug didn't have any metal shavings on it pretty much, front diff looks good.
Will be replacing MAS today, whole part, if Amazon doesn't loose it again.
Initially was going to be here last Sunday, then it lost, Amazon sent it again with being "delivered today".
Drewphil
