06 Escalade oil leak rear of engine?
drhill
Hi Everyone,
I have a stubborn oil leak at the rear of the engine in my 2006 Escalade. I just replated the oil pan gasket with oil cooler gasket, timing cover gasket, valve cover gaskets and did a new oil pump and o ring and water pump while I was in there. The flexplate and torque converter area was clean and dry when I removed the plastic covers. Drips are dropping from the rear starter bolt on the passenger side, the rearmost pan bolt on the drivers side and it appears on the bottom of the bellhousing. Is there an oil sending unit on the back of the block somewhere? Doesn't appear to be form the rear main seal or the rear cover - wouldn't there be oil on the flexplate etc if so?
Thanks for the help!
MassHoe04
Western MA
Oil pressure sensor is at the back of the engine block, practically above the flywheel at 12 o'clock position. Could explain oil dribbling down both sides. The OPS is a fairly common thing to leak or start giving bad readings with old age.
See if you can get a little inspection mirror over the top of the flywheel area (or one of those colonoscopy camera probes) to see if that is leaking.
MassHoe04
Western MA
I posted link to Silverado forum with similar described leak. But that turned out to be a Detroit Diesel motor...
Disregard.
For what it was worth, though... The Detroit Diesel was drippy on the bottom of the bell housing, but inside the bell housing and torque converter area were bone dry, like yours. His leak turned out to be oil pan gasket.
rockola1971
Indiana (formerly IL)
OPS is where it has been for over 50 years now. Right behind the Distributor.....or in our case on the LS series engines.....right behind where the distributor would be if we didnt have distributorless ignition (DIS). :p
Not uncommon at all for the OPS body to develop a leak and start puking black gold down the back or passenger side of the block. Wipe it good and clean around the OPS and go for a drive and check if its wet with oil.
GMT800 2005 Tahoe Z71
Navy Supporting Member
My vote is either the OPS or the cam sensor leaking or back of valley cover BUT, you may have actually been fixing the correct leak but may have had a faulty part or may not have sealed it correctly and is still leaking. I don't know your mechanical abilities and am not pointing fingers and is why I said MAY, but it does happen. Also, can still be leaking at rear main seal assembly because the oil does not ALWAYS leave the trail you expect to see at the flexplate and torque converter.
When I have had or seen leaks that have leaked long enough that so many spots that could be leaking, are covered with oil from oil leak being blown around from turbulence under the hood and then it turns in to guess work. I like to completely clean and dry and drive and look again and/or use dye and a blacklight. That efforts time and money could have easily been covered by the time and money you have spent so far and then if you choose to go deeper, that is a choice instead of an attempt at a guess.
D
drhill
You are right, things happen and sometimes the repair does not work if you rush it don't prep surfaces etc. Always appreciate input and advice from an ASE guy. I was starting to see the signs of a bad o ring seal on the oil pump pickup (low oil pressure at idle etc) so between that and the oil leaks I figured it was time to go in and fix a few things. On a 200k mile engine that is covered in sludge, I'm happy to spend a few $$ fixing leaks.
I did clean everything as best as I could during the repair work and once a saw a small leak after the repair, it was finally clean enough to see the general area it was coming from. I know this engine had multiple leaks and I know I took care of a few of them already that have not returned (valve covers and timing cover/balancer seal). If it's the rear main or rear cover, it's gonna stay until the trans needs a rebuild. But I'll check rear of motor by the 2 sensors and the valley in the morning when it's cool and see what I can find.
MassHoe04
Western MA
After owning a number of older cars, trucks and SUVs...
I have learned to observe what things look like on a normal day and keep an eye out for the differences between the "slow daily weep-age" and what might be a "new critical leak".
After a while you become de-sensitized to the normal weeps and drips of an old vehicle and stay alert for leaks that could soak an alternator, starter, belts or other critical components.
Obviously repairing serious things needing attention, but doing so when it makes sense and I can afford it.
Anyone who has been accustomed to having only new vehicles, restored show cars or OCD... Then, I can see how what might be "acceptable" for some folks on old daily driver might be a really hard to not stress about leaks popping up here or there.
If this were mine and was an easy and cheap fix (like one of those sensors), I would go for it. As OP states, if it is the RMS... I would hold off until the tranny HAD to come out.
mattbta
Frisco, TX
Anecdote - I was one of those that somehow boogered up my cam sensor install. I don’t know if it happened during original install or if I pulled it out and reinstalled the second time I had to pull heads for a crack. The o-ring was mangled and off kilter.
Didn’t discover it until I paid a shop to do the rear main due to massive oil leak from above. But the rear main was a little wet, too.
The ironic thing is I replaced the cps because it is a known leak point. :eek:
Eliminate the easy stuff as others said. Valve cover, valley cover, oil pan gaskets, oil cooler block off, oil sensor, cam sensor, crank sensor. From there if I remember correctly that only leaves timing cover and rear main/cover.
Good luck.
D
drhill
I'll be pulling the intake this week...so far it does look like some form of leaking at the rear of the engine. If it wasn't destroying my concrete driveway I honestly wouldn't care so much but I'm tired of cleaning up after this truck! M y other Escalade with 250k doesn't leak at all after a few fixes but was obviously taken care of even before my ownership
treehan77
TYF Fiend
Crestview, FL
I’ve had the same leak for a while, off the starter bolt. I replaced the oil pressure sending unit (twice), did the valve covers, cam sensor, oil block off gasket, valley, oil pan gasket, it has never changed. I told myself the trans would die one day and I’d do the rear main then. Well, 7 years later it’s still leaking the same and the trans refuses to die. I purchased the rear cover with seal installed, so I’m sure 2 months after I do it the trans will die lol
Keep us posted on the fix, please!
Maximus05Escalade
OPS and cam sensor is where I would look first, and the rear valley pan gasket. Here is my experience with the same oil leak you are having. If you're not having knock sensor issues yet more than likely you will be soon. I am suggesting pull the intake because those gaskets are leaking you can bet on that, do valve cover gaskets, knock sensors, knock sensor harness, valley pan gasket, ops and cps. This is not throwing parts at it but rather saving you from taking everything apart 3 or 4 times to do these things anyway. The oil fill tube is probably leaking too and can be removed while valve cover is removed. You can replace it or just screw oil fill cap directly into valve cover. Also make sure pcv and oil trough if you will ,are clear on the driver's side valve cover. This being plugged can build crankcase pressure in turn causing more oil leaks and/or worsening already existing ones. Sounds like a lot but isn't hard just a little time consuming. more clean up then anything. If oil still shows up on starter bolts after that it is either your crank shaft positioning sensor and/or the oil dipstick tube. Speaking from my personal experience with my 05 Escalade,255k miles. LQ9. It is still very strong and runs great. At the age of these vehicles, they owe us nothing but are worth the returned love. It's a choice, payment or new parts or simply because we love the year and model of your vehicle. Good luck in your oil leak adventure. It's a process that can get frustrating, but you will get it. Just be prepared that it will be several things leaking not just one.
Maximus05Escalade
I was able to get a clear pic with my phone of the ops, rear of valley pan gasket and back of heads/ valve cover gaskets. All were leaking but the ops will pump the oil out back there and it will run down both sides. Start with the easy stuff. Still wouldn't count out the rear main even though it appears dry.
BadDaddy2003
