Soft Brakes, New Day
nick0789
2005 Z71 tahoe with hydroboost
Issue
soft brakes for the first 2-3” of pedal travel then I finally start getting bite.
When did this start?
It started earlier this year after I replaced the hydroboost unit (new GM) and master cylinder (new GM). Why? I flushed my power steering pump and ended up springing a leak in the inner seal of the hydroboost unit and started with the softer brake feel.
Did you bleed the brakes after this?
sure did. I went through the whole process twice and didn’t observe any additional air coming out at any of the calipers on the second pass. First pass was done with Motive pressure bleeder, second pass was done manually.
I had mostly forgotten about it as my Tahoe has never had the braking potential of a Porsche, but after driving a rental all weekend on vacation and coming back to the soft brakes I knew I had to revisit it. Today I went back to the brakes and cycled the ABS unit twice (auto bleed function on my tool) and then re-bled all four corners … with no air visible upon bleeding.
The brakes feel marginally better but are still soft. What are my options at this point?
When I push the pedal and then release it springs back no issue so I was under the assumption that I had air in the lines still (or ABS unit). During normal driving of the vehicle I can occasionally get firm brakes but rarely do I get them in the mornings which makes me think (part of) my issue could be coming from whatever front brakes the PO had installed. I have had this vehicle for almost 5 years (~50k miles) and the front pads haven’t been changed during my ownership: quite frankly they still look to be 60-70% so I have no idea what friction material they are. I thought about replacing them as PM anyways but wanted to see about anything I may be missing.
Thanks!
B-train
OK, not to question your skills because they sound on par, but when you did the manual bleed did you have someone pump the pedal while you were at each wheel to Crack the bleeder under pressure?
The reason for asking is because I've been there, done that. Sometimes a second person is necessary to get a good job, instead of a machine. Again, just my experience.
My other thoughts/questions are 1) how does the truck stop? Good w/o having to stand on the pedal, or mediocre? 2)Was there any adjustment that could be made for the brake pedal rod?
If it stops better after using the brakes, it could be a friction issue, but you would think that would feel the same no matter what.
Or, lastly is the new master cylinder bypassing internally and after some use the cups get reset and work better. Try doing a QUICK brake stab and see how the pedal feels. That will tell you if the mater is bypassing or working properly. If it's bypassing and you stab the brakes, most times you'll end up with a solid pedal. Then it will go limp again when used as normal after a rest period
N
nick0789
You’re not going to offend me lol.
I had a second helper for both the pressure bleeding and manual bleeding process, and the bleeder screws were not opened unless the motive canister was pressurized or the helper was holding the brake pedal (and it was closed before either of these two were stopped). The first time I bled brakes on my old Jeep I learned real quick about air flow lol
Stopping feels mediocre, around a 6/10. I’m not sure I’d trust it in a sheer panic stop at this point.
For the hydroboost unit I did not see anything that would have been something I could adjust with the rod. I do have the brake pedals that can be height-adjusted but I have gone through that portion in the past as well just to see.
Braking sometimes /occasionally feels better after city driving but I can’t pinpoint that it’s due to the pads being warm.
I’ll look at the master cylinder possibility in the morning.
Thanks again!
N
nick0789
After changing the master cylinder it likely needs an ABS bleed procedure.
When I replaced the master cylinder (however many months ago) I found a thread on the forum that showed how to bypass needing a scan tool to bleed the ABS module. It involved cycling the ignition and I did notice small amounts of air coming out during bleeding after doing this step.
I used a scan tool today to auto-bleed the ABS module. For my tool I have to hold the brake pedal down while it automatically cycles the ABS unit. I will admit that the first time I did it I thought it finally worked because the pedal pushed back on my foot pretty firmly during the first couple cycles of the auto-bleed procedure … then it went back to somewhat soft so I figured any air got pushed into the lines. Re-bleeding manually (with a helper) didn’t produce any air bubbles though
Scottydoggs
NJ
you need to lift the front wheels off the ground. engine on pump the brakes 30 times. turn it off. turn the wheels lock to lock 15 times. open the p/s pump cap before hand. lay some card board under it cause the trapped air will burp and push fluid out the top. if you leave the cap on it will still burp out past the cap, but will spray all over.
B-train
That is brilliant! That idea totally escaped me. It's the same as replacing a rack and pinion......20 years ago here, so a little rusty. Makes a lot of sense.
Scottydoggs
NJ
same idea, but this bleeds the booster. we got a work truck with a slow leak on ps hose. pedal gets mushy here and there. i do that and the brakes are back.
Larryjb
I remember reading somewhere about how difficult it can be to bleed air out from master cylinder. I believe that an air pocket can still reside even after bench bleeding. If I recall correctly, if you park on a hill facing down so that the rear of the master cylinder bore is pointed slightly up, and then bleed it, you can get out some of that trapped air.
Found an article about it here: https://www.brakebleeder.com/removing-trapped-air-angled-master-cylinder/
BoatyMcBoatface
Northeast PA
I know this may sound odd but i had a problem with another vehicle with the same crappy feed back of the brake pedal. I tried a few things and once i changed out the pads to semi metallic. used a name brand fleet rated and the brake response was immediate. I'm not saying that's your issue but organic cheapo pads even with high pressure behind them leave a soft braking feel. I would also make sure your hydro boost is working correctly. With the vehicle off pump the brakes till the pedal gets firm. Keep your foot on the pedal and start the vehicle, the hydraulic pressure should start to push the pedal back up as it builds. We have a Lincoln and i just replaced the pads and the previous pads gave me the same lackluster feel. I the pedal would go quite a bit and even standing on the brakes i was sure they would never lock up. I put a set of semi metallics all the way around and a toe on the pedal makes it stop on a dime.
N
nick0789
Morning Update:
I went ahead and went through the hydroboost bleeding procedure scottydoggs outlined and did not notice an improvement. I looked into the PS reservoir and did not notice any bubbles or foaming.
I took temps of the brake rotors after driving to work this morning and the fronts were definitely cooler than the rears (like 20-25% cooler). It seems somewhat counterintuitive to me so I went ahead and ordered new pads, rotors, and guide pins as I have the torx bolts. If nothing else it allows me to break down the front brakes and clean everything up, and I will go ahead and re-bleed the master cylinder on the vehicle during this process in the event that I still have trapped air at the end of the cylinder.
I'll provide an update at some point over the weekend with what the outcome is. Thanks again for all the input!
rockola1971
Indiana (formerly IL)
Morning Update:
Front brakes provide roughly 80% of your braking power and thats "hardwired" into your brake system via the proportional valve. So I would expect the front brakes to be warmer than the rear. You dont want your rear brakes overbraking past your front brakes, that ends up being a squirrelly 2 1/2 ton with 4 wheels with you behind the steering wheel! It is NOT a fun ride. Especially on gravel, ice and wet roads.
Scottydoggs
NJ
newer cars and trucks use much more rear brake. all of the work trucks eat the rears way before the fronts. same goes for my 03 pick up i sold. as well as my 05 tahoe. work trucks are 3500's a 05 and a 15. even my 98 regal would use up the rears first no matter what brand pads i used.
Buggdave
SLC , Utah
Just another thought, when I added hydro boost to my rig, I also changed out the flex hose to each caliper with stainless steel braided. I know that with age, the rubber ones will expand a little and take way some of the hydraulic force going to the calipers. I did not see you mention if you had changed these yet on your setup.
N
nick0789
Weekend Update:
I went ahead and replaced all five rubber brake lines (with rubber), gravity bled the system at each corner as I worked through the hoses, replaced the front rotors and pads, and replaced the caliper bolts / guide pins. Then I bled the system again and saw absolutely zero air at the end of it all.
I just took the tahoe for a shake down test drive and to also bed the brakes until they STANK.
I can pull part numbers if anyone ends up needing them for whatever reason but I went with NAPA hoses (AKA repackaged Sunsong hoses), NAPA ultra premium coated rotors, and Akebono ProACT (ACT785) pads.
Overall there is a noticeable improvement in braking and pedal feel once the engine warms up, though not too terribly noticeable when cold — I’m assuming this is due to the power steering and/or hydroboost needing time to warm up??
A few final notes from my “project” of the day:
1) who’s idea was it to use a soft line in the rear center of the vehicle where there is almost zero room for a wrench to rotate? I dropped the spare tire and was was able to get a stubby 9/16” wrench to remove the flare nut, though I would have really preferred to use a line wrench but oh well. It still took over 45 minutes to loosen, clean up, feed the new hose, install, and check for leaks during gravity bleeding for this one hose all while in a very uncomfortable working position.
2) who’s idea was it to use female T55 torx bolts for the front caliper guide pins? Those things are a JOKE. Im glad I looked into it before I even ordered parts so I knew what I was getting myself into but it was ridiculous: I twisted my first T55 socket when trying to remove the passenger lower bolt and had to run to the store to get a new socket … then I get back and went to town on it with my impact driver and that thing would NOT budge. I ended up pulling the caliper anyways so I took it aside and heated the bolt with a torch and it finally broke free. I clearly took the smart route during reinstall and swapped the bolts for the hex heads.
3) the driver’s front pads were STUCK to the caliper bracket. I didn’t see any evidence that the caliper wasn’t working anymore, as the old rotor was always shiny and the new rotor had the coating strip off just like the passenger side, but I still spent a solid 10-15 minutes trying to remove the stuck pads with a deadblow.
All in all, I took my time and invested over 8 hours to get it all done and tested. If I had to do it again on another tahoe tomorrow I’d likely be done in 4-5 hours
rockola1971
My 05 Denali with hydroboost the brakes are firm even at cold engine start. But I bled my system with a Tech 2 using the auto feature which gets rid of the air behind and in the solenoids of the ABS manifold.
N
nick0789
My 05 Denali with hydroboost the brakes are firm even at cold engine start. But I bled my system with a Tech 2 using the auto feature which gets rid of the behind and in the solenoids of the ABS manifold.
Thanks for the catch. I didn’t note that I also bled the ABS module with my scan tool twice as well. I’ll go back out and bleed the module and corners one more time at some point before Monday and see if I get any improvement.
N
nick0789
Update: there was no improvement in pedal feel with additional ABS bleeding and bleeding at the corners afterwards.
I’ll be testing the power steering pump pressure as I have also been feeling some still steering wheel response when in the parking lot.
In the event that this test comes back with less-than-ideal results is this the power steering pump everyone would recommend? I’ll also be changing the two lines in the process but I have the BPH RPO code so this and the AC Delco website were slightly confusing.
If there are other recommendations for PS pumps I’ll be happy to hear them. I’d like to stay away from remanned units if possible but if there is a consensus I’ll listen to the crowd.
Thanks again!
Thanks again!
Does the pedal feel change when revving the engine? Have you driven in a lower gear to get the RPM up and tested the braking?
B-train
I personally stay away from reman products. Got burnt too many times years back......it sucks doing the same job twice and sometimes not able to get paid for the second time.
Find a good name company that offers new with warranty. I've used car quest and napa in the past and had decent luck. Lately though I have been going more to the OEM stuff whenever possible. Having online competition has made the OE stuff more competitive price wise.
Buford bubba
